Old 11-01-2007, 06:38 PM
Default What's your answer to this question??
Old 11-01-2007, 06:42 PM
Rick Parker's Avatar
I would say #3
Old 11-01-2007, 06:44 PM
jwd's Avatar
jwd jwd is offline
Definately #3
Old 11-01-2007, 06:47 PM
two is the answer
vanoochka's Avatar
California Dreamin Member
Send a message via ICQ to vanoochka Send a message via Yahoo to vanoochka Send a message via Skype™ to vanoochka
#5 - Because it's there.
Old 11-01-2007, 06:48 PM
Oh...this is going to be good....
Old 11-01-2007, 06:49 PM
vettestr's Avatar
# 3 describes a normally aspirated engine.
Jeff Classic
Manufacturer of the Cobray-C3
www.cobrasnvettes.com
Old 11-01-2007, 06:57 PM
bmwdb10's Avatar
Cobra Make, Engine: Gulf GT40 CAV137, Cobra ERA286
I agree with Mr. Bruce! #2! I think there is more vac with the down stroke and open valve than outside pres.
Gulf GT40 CAV137
427 Cobra ERA286
Old 11-01-2007, 06:58 PM
Chaplin's Avatar
Originally Posted by mr bruce
two is the answer
That is Correct!
Replica is not a dirty word.
Old 11-01-2007, 07:02 PM
Go out to the garage, take off your aircleaner. Place you hand over the carb. What do you feel, NUTHIN'. Now start your engine, what do you feel, SUCTION.Piston PULLING the fuel/air charge into the cylinder.
Old 11-01-2007, 07:07 PM
computerworks's Avatar
During the intake stroke of a naturally aspirated engine, a vacuum in created. Because the pressure inside the cylinder is now lower then atmospheric pressure, air enters the cylinder and the pressure is equalized.
Lousy wording of the answers.
3. ...but I'd give the 2's a correct answer also.
pgermond's Avatar
The #3's have superchargers!!!
Phil
http://www.uniquecobra.com/
Old 11-01-2007, 07:08 PM
Yetiman's Avatar
Cobra Make, Engine: Arntz/SBC/Jag
I know what test this is from !
I had a lot more head scratching in the section with the pulleys.
We come into this world naked, screaming, and covered in blood. With dedication and a little planning, you can go out the same way.
View my overflow Gallery (much more to come !)
Old 11-01-2007, 07:17 PM
vanoochka's Avatar
When the piston goes down, it causes a vacuum - a volume of space in which the gaseous pressure is much less than standard atmospheric pressure. That would lead me to guess that the answer is #3 because when the valve opens the air would be pushed into the vacuum at a pressure of 14.7 lbs per square inch.
Old 11-01-2007, 07:18 PM
fasterpatrick's Avatar
Cobra Make, Engine: scratch build self design 4.6l DOHC
It's three let them take the whole test, I got 98%, I know I got it wrong the first time.
How smart are you
http://www.forddoctorsdts.com/quizze...alAptitude.php
Patrick
Old 11-01-2007, 07:20 PM
I got a 94... 96 is the question 48 is B.....lol
Old 11-01-2007, 07:22 PM
jwd's Avatar
jwd jwd is offline
The Intake Stroke:
On the intake stroke, the intake valve has opened. The piston is moving down, and a mixture of air and vaporized fuel is being pushed by atmospheric pressure into the cylinder through the intake valve port.
I've worked with pumps for 30+ years. This is basic stuff.
Old 11-01-2007, 07:33 PM
So when I breath and my lungs expand....atmospheris pressure is filling my lungs, or are my lungs causing a vacuum sucking air in??
Old 11-01-2007, 07:42 PM
Cobra Make, Engine: csx4163 comp
why would you lose h.p. at higher altitude?
truss 1x
Old 11-01-2007, 07:44 PM
Chaplin's Avatar
less oxygen in the air.
