SUPPORT OUR SPONSOR
Old 01-14-2008, 05:54 PM
Cobra Make, Engine: Midstates in-work again
Default Engine mounting angle
I am installing sm blk ford with t-5 trans. Anyone know what the angle is for the centerline of crank?
Treblig
Old 01-14-2008, 06:33 PM
bobcowan's Avatar
I think you're referring to the Power Angle. That's the front to rear downward slope of the driveline. Gnerally instaleld at 5*. But with EFI it really doesn't matter.
Old 01-14-2008, 07:02 PM
Way back when I built a V-8 ( 283 ) Vega. I think I read something on the downward slope angle of the crankshift which is in-line with the transmission drive shaft. The number that come to mind is 3 to 4 degrees and the angle for the drive shaft at transmission plus angle at rear end yoke has to equal 180 degrees.
Treblig
Old 01-14-2008, 07:23 PM
Cobra Make, Engine: spf 2112 *427 stroker windsor
Hello Treblig; could you post a sketch of what you just explained. Thanks Carmine
Old 01-14-2008, 07:40 PM
mickmate's Avatar
BB uses 2.5 deg
mickmate
http://www.actoncustom.com/
HTML code is On
