SUPPORT OUR SPONSOR
Old 11-25-2008, 03:37 AM
Cool TBird Turbo Coupe Rear 5 Lug Conversion
Some one must have done this before.
I have a 1988 Thunderbird Turbo Coupe rear, disc brake, which came with 4 lug pattern. The vented rotors are 10". I've swapped out the axles for 5 lug and now find that 10", 5 lug rotors aren't available.
Other than redrilling the 4 lug pattern to 5 (Don't like the idea.)
Modify the brackets to accept 10.5" 5 lug rotors from a Mark VII.
Any help is greatly appreciated as I have to believe this conversion has been done using something off the shelf.
Old 11-25-2008, 04:31 AM
What did the 84-86 Mustang SVO use? They were 5 lug, but not sure of the rotor diameter. They may be hard to find though. Try this site:
http://mjbobbitt.home.comcast.net/~m...tang/5lug.html
Old 11-25-2008, 06:07 AM
LMH's Avatar
LMH LMH is offline
Try these guys.
http://discbrakesrus.com/make/ford/brakerotorsrear.htm
Old 11-25-2008, 05:57 PM
Thanx for the assistance. It appears from what I've read the standard 4 lug 10" brake rotor is drilled for 5 lugs and the center hole opened up to fit the axle. I appreciate the replies and sure will have many more questions in the future!
HTML code is On
