SUPPORT OUR SPONSOR
Old 06-03-2009, 05:56 PM
EarlsflyinCobra's Avatar
Ouch Ouch Hot Sand
Cobra Make, Engine: Street Beasts w/302 Twin Turbocharged....Under Construction!!
Send a message via AIM to EarlsflyinCobra
Default Wiring question?????
I have a Kwik Wire kit and there is a 10 gauge wire that says Starter Solenoid B+.....it says to splice the supplied fusieble link to the end of the wire before attaching it to the starter......the fusible link says.................. 2.0 sq. mm fusible link on it.......my question is to do away with the fusible link do I;
A; put in a 30 amp slow blow fuse in place of the F.L.
B; put in a 50 amp maxi fuse in place of the F.L.
I have been told both and am not sure which one I should do?????
Any help from you WIRING GURUS out there?????????
Safe Flyin, errrrr Drivin, Earl
HTML code is On
