Old 07-10-2009, 04:11 PM
FUNFER2's Avatar
Default Side pipe mount vibration isolator ?
I'm wanting to find a better vibration isolator for my side pipes, any ideas ?
Kevin
Old 07-10-2009, 04:20 PM
Try McMaster-Carr http://www.mcmaster.com/#vibration-isolators
Terry
Old 07-10-2009, 04:24 PM
FUNFER2's Avatar
lol, like yourself, I just looked at this type also. On the page you linked, can it be wider ? Having a problem seeing their products. (not computer savvy)
http://www.globalspec.com/FeaturedPr...romAreaId=1440
Kevin
Old 07-10-2009, 04:28 PM
Kevin,
I deal with McMaster a lot. Have it in my favorites. They have many differant types there and I have never found that they were not able to ship right away. Good prices also.
Terry
Old 07-10-2009, 04:32 PM
Banned
Have you considered the mounts that SPF uses? They actually work quite well. I can send you some pics this weekend if you can wait a day or two. Not sure how your current configuration looks like, so I can't determine whether or not you would need to weld a different tab/rod to your existing set-up to make them work.
-Dean
Old 07-10-2009, 04:41 PM
Default You Mean These Things?
These things? They just appear to be big-a$$ chunks of rubber on the ERA cars. They do work well though.
Old 07-10-2009, 05:11 PM
FUNFER2's Avatar
Terry- I'll look them over. I assume you have one of theirs, do you know which one ?
Dean, that would be great.
Patrick- That's gotta be strong. How does it dampen the vibration though ?
Kevin
Old 07-10-2009, 05:23 PM
Apparently that big rubber vertical piece absorbs the vibration and provides structural integrity as well. I'd be interested in seeing shots of what the other manufacturers use.
Old 07-10-2009, 05:52 PM
FUNFER2's Avatar
Oh, ok, I see that's it rubber and not metal. The coloring is about the same.
I wonder how stiff it is ?
(no pun intended)
Kevin
Old 07-10-2009, 05:57 PM
FUNFER2's Avatar
This is what the SPF has. This pic is too far away but, the 1/4 round part welds to the muffler housing and the two bolts have a type of rocker arm assembly. Larger photo.
Kevin
Old 07-10-2009, 06:10 PM
That doesn't look that great. Can somebody post a shot of what the Kirkhams use?
Old 07-10-2009, 06:16 PM
Thats not the way mine are made on car# 2592. Are you sure these are SPF?
Rodger
Old 07-10-2009, 06:21 PM
FUNFER2's Avatar
Like Terry mentioned from that company. See if any would stand out as the best type.
Leveling MountsAbout Leveling and Vibration-Damping Mounts
Select a mount with a maximum load closest to your machine's "load per mount." When using multiple mounts in applications where weight is not evenly distributed, choose each individual mount based on the maximum load it will be supporting. For static loads where weight is evenly distributed, use the following formula to select the proper mounts:
Total Machine Weight divided by No. of Mounting Points = Load Per Mount
Leveling Mounts— In addition to leveling the supports or legs of a machine or other piece of equipment, they let you position equipment above the floor for easier cleaning and inspection.
Leveling mounts that swivel can be used to compensate for uneven floors.
Vibration-Damping Mounts— Isolate vibration, shock, and noise transmitted to and from machinery. They reduce maintenance costs, prolong equipment life, and protect floors. Performance is measured by deflection (the distance the mount material moves when subjected to force). Generally, the higher the deflection rating, the greater the vibration, shock, and noise isolation. Most vibration-damping mounts are used in vertical (compression) applications. Some mounts can be used in both horizontal (shear) and vertical applications. Still others have a steel insert running through the center of the mount that provides support for axial loads (parallel to the stud hole) and radial loads (perpendicular to the stud hole).
Kevin
Old 07-10-2009, 07:36 PM
FUNFER2's Avatar
This is from a owner of a SPF and it may be different from others.
Kevin
Old 07-10-2009, 07:40 PM
jwoodard's Avatar
Thumbs down
I think you got some bad info on the SPF mounts. They don't look anything like that.
Jim Woodard
Old 07-10-2009, 08:25 PM
mickmate's Avatar
Sway bar links.
mickmate
http://www.actoncustom.com/
Old 07-10-2009, 10:17 PM
Rick Parker's Avatar
Go to a muffler shop. They use some round isolaters that sandwich an 1/8" thick piece of metal and work very well. A 5/16" or 3/8" bolt goes through the center. These work very well and are easy to get and CHEAP!!! See my intalled pipes below.
[IMG][/IMG]
Old 07-11-2009, 01:23 AM
FUNFER2's Avatar
Jim- like i stated, this is an owner of a SPF that has that mount, not all SPF's.
Rick- I'll go to a shop this weekend. Thanks for the tip.
Kevin
Old 07-11-2009, 05:37 AM
Senile Club Cobra Member
That is NOT the current SPF sidepipe mount. I will get a picture Sunday and post. I have the mouints in stock.
rick@autoventureusa.net
Old 07-11-2009, 06:00 AM
Default FFR Mounts
As a helpful comparison, here's a shot of the FFR mounts.
