Old 07-11-2009, 08:00 AM
Jerry Clayton's Avatar
Is that stainless steel???
Old 07-11-2009, 08:44 AM
FUNFER2's Avatar
MarkIV- Do I really need to quote myself this again !
"This is from a owner of a SPF and it may be different from others".
IT MAY BE DIFFERENT FROM OTHERS !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Comprehend now ?
Kevin
Old 07-11-2009, 09:40 AM
Kevin,
I agree the mounts on your friends car may be different from others.....he either must not have original SPF sidepipes and/or sidepipe mounts. I remember seeing that bracket on a sidepipe website, but I can't remember where. I know for a fact it is not an original SPF mounting bracket.
These are what SPF supplies. The first picture is from the Superformance Mark III Installation Manual. The other 2 are of my original sidepipes:
Rodger
Old 07-11-2009, 09:52 AM
FUNFER2's Avatar
Those look strong. Is there any rubber used ?
Can you enlarge the photo's ?
Kevin
Old 07-11-2009, 09:57 AM
Silverback51's Avatar
Originally Posted by RodgerH View Post
Kevin,
Rodger
Those are what I have on my SPF.
John Hall
Old 07-11-2009, 10:47 PM
Rick Parker's Avatar
In Patricks picture above, the bracket attached to the muffler is designed very similar to what I observed on a CSX3XXX car a few years ago. It has a lot of surface area attached to the muffler casing in vertical shear and with the 90 degree fold in the metal provides lateral stability also. However in lieu of the large rubber "Strap" on the ERA cars, the CSX had 2 "hangers" spaced about 3/4" apart, made of similar gauge sheet metal (like the bracket) welded from above. The blade on the muffler bracket had a hole about 5/8" and is sandwiched with one of the round 2 piece grommets I mentioned earlier, then the blade (with grommet) slides between the two hangers and a 5/16" bolt goes through all 3 pieces, providing a very stout design. The rubber grommet helps dampen the sound harmonics from the chassis.
Here is mine:
Sorry for the unfocused picture, 11:30pm on your back under the car after a day at work is at best questioned???
[IMG][/IMG]
Old 07-12-2009, 06:11 AM
undy's Avatar
As a helpful comparison, here's a shot of the FFR mounts.
Uh oh... jus' when you thought it was safe after the "FFR snubbed my Cobra thread" ....
Too many toys?? never!
Old 07-12-2009, 07:23 AM
I neglected to include the appropriate fasterners.
Old 07-12-2009, 08:24 AM
Cobra Make, Engine: ERA #726 427 SOHC
I've been using rod ends with great success.
Old 07-12-2009, 08:38 AM
Aussie Mike's Avatar
I made these mounts from billet.
They use a cotton reel rubber mount like this between the alloy piece and the chassis outrigger.
Seem to work OK.
Mike Murphy
Melbourne Australia
Old 07-12-2009, 09:36 AM
Default Isolaters
Terry- I'll look them over. I assume you have one of theirs, do you know which one ?
Dean, that would be great.
Patrick- That's gotta be strong. How does it dampen the vibration though ?
With the way the Classic Roadster is set up I use a 3/8 thick rubber washer on each side of the flange, a flat washer and the bolt. That is it for mine.
Terry
Old 07-12-2009, 12:20 PM
trularin's Avatar
Member of the north
Cobra Make, Engine: A Cobra
Terry, I use something like that with 1/4 hard rubber.
Works well.
  #33 (permalink)
Old 07-13-2009, 02:04 AM
FUNFER2's Avatar
(Rick- Great pics you have in your files. I like the titled "Bruce 4271", with the modern EFI type air filter, I would imagine very good surface area)
Kevin
  #34 (permalink)
Old 07-13-2009, 07:35 AM
You failed to include a pic of the mounting tool:
  #35 (permalink)
Old 07-13-2009, 09:43 AM
kitcarbp's Avatar
Default Exhaust Pipe Mount
Here is pic of sidepipe bracket used on my West Coast. Its a Walker Part number but I dont know where to find it. Two 5/16 bolts mount it into the chassis rail's steel nut-serts. Rectangular piece of dense rubber is molded with a slot to accept the steel tab off of the pipe. This pic is a top view.
  #36 (permalink)
Old 07-13-2009, 10:04 AM
Banned
As promised, here are the SPF mounts:
The stem off the sidepipe has a welded on bolt that fits through the isolator section. Works very well. You just have to make sure that the stems are welded on straight so that you don't have any load/shear on them when they are bolted on. You will also notice that I braced the factory stem with more material, as they are prone to cracking.
-Dean
  #37 (permalink)
Old 07-13-2009, 10:08 AM
767Jockey's Avatar
Contemporary used sway bar links from of all things a '57 Chevy. It's real simple, it's cheap, and it works well. Moog part number K6217.
  #38 (permalink)
Old 07-25-2009, 12:58 AM
Cobra Make, Engine: Superformance - FE
Dean,
Yes, that is the picture of the frame mount. The problem with the tang that mounts to the pipe is the weld has broken on some. The picture that Kevin is showing is the mount that I use. It is made out of stainless and uses a taping plate for a better foot print to weld on the muffler body. When mounted to the car it attaches to the Superformance frame detail. We have found it to be strong enought for an average person to stand on. Your mount to the muffler body is a good reinforcement to the supplied standard mount. If I can be of any help please let me know.
Ron Roberts SPF-1535
