SUPPORT OUR SPONSOR
Old 08-17-2009, 12:25 PM
cobrarkc's Avatar
Cobra Make, Engine: Contemporary 482 all aluminum Tunnelport Self built and owned since 1980 frame#0000017 and owner of frame CCX 33961 looking for an FIA body to go with it
Default Alcohol/aluminum compatibilty?
I am having a gas tank made up for me by a member of this forum (Mickmate) Nick Acton. Right now gas contains 10% methanol but who knows in the future what it will be, maybe it will all be E85. I only want to do this once and do it right. Is an aluminum tank going to hold up with alcohol?
Cobrarich
Old 08-17-2009, 12:49 PM
Banned
Low doses of alcohol (~10%) will not have a concerning effect on aluminum. The E85 probably would, but if you have to run that then you need to convert your EFI/carburation to handle an alcohol (methonal) concentrated fuel. Anodizing aluminum surfaces has the affect of slowing down/stopping any decaying effects that alcohol has on it. It can be an expensive process though, especially for the entire interior of a fuel cell/tank.
-Dean
Old 08-17-2009, 03:28 PM
Use a 5052 alloy for the tank. It's about the best of the common alloys for corrosion resistance (it's also known as "Marine-grade aluminum"). We've been using it in our tanks for almost 30 years without a problem.
Old 08-17-2009, 04:47 PM
mickmate's Avatar
Thanks Bob that's what I use. The last tank I pulled concerned me as it looked like a layer of corn syrup on the bottom. Part of the problems we're going to see more of with vehicles that sit I assume. I'm hearing recommendations for using Stabil or similar products all the time to stop separation. My hot rod buddies are having a tough time with the float bowls on Holleys getting eaten out on the insides.
mickmate
http://www.actoncustom.com/
HTML code is On
