Old 09-03-2009, 04:07 PM
Cobra Make, Engine: jbl
Default afr change from flat base to drop base filter
had something interesting happen when i changed from flat base filter to drop base. was trying to increase my field of view so thought i would try drop base filter. same size filter 4" x 14", same top.
afr at cruise went from 14.5 up to around 16-1. didn't know if something happened at the track or changing to straight through exhaust did this, so i put the flat base back on and the cruise afr returned to normal. the top i didn't think was very close to the carb inlet but it must have disrupted the airflow somewhat. wot didn't appear to change much that i could tell. anyway, definitely had not expected this. looks like the protrusion lives another day.
here's a picture with the flat base, the drop base was 1.5"-2" lower, same filter & top.
Old 09-03-2009, 04:17 PM
jdean's Avatar
So you are back to the "Beyond Thunderdome" theme for a while
6th generation Texan....
Old 09-03-2009, 05:47 PM
lol, haven't come up with a better one yet.
what's the word on your car? any pics of the scoop?
Old 09-03-2009, 06:59 PM
jdean's Avatar
Hope to have some pics by tomorrow....if so I will post them here.
Old 09-04-2009, 10:30 AM
danc30's Avatar
Cobra Make, Engine: Hurricane HM1073 Keith Craft Genesis 427FE/482 CI
I would keep the drop base. Going from 14.5 to 16 means you are getting more air, better airflow. Not sure if you have a carb or FI, but I would richen it up either way.
I think this is an accurate assumption.
Old 09-04-2009, 02:22 PM
i hadn't thought of it that way. i figured it was a disruption of the airflow through the carb. thnx.
Old 09-04-2009, 05:29 PM
jdean's Avatar
Makes sense to me. If AFR went richer it would mean less air getting through.
