SUPPORT OUR SPONSOR
Old 09-09-2009, 06:37 AM
kitcarbp's Avatar
Cobra Make, Engine: West Coast, 460 Ford Racing Crate w/ TREMEC TKO 600
Default Need a Cooling Fan Switch- 2 TEMP set points
Can anyone share a cooling fan switch they are using that is an OEM type that uses two pins, with each pin grounding at different temperature set points to activate a cooling fan circuit ? Example would be the first pin grounds at 195F and the second at 210 F ? This would make controlling my twin fan set-up easier than installing a PWM sytle controller or installing two separate switches ?
Thanks
Bill
"...some assembly required, ages 8 and up...... well that took longer than expected......
HTML code is On
