11-20-2009, 07:45 PM
Finally trunk supports.
Thanks to Tucson Jonh I got trunk supports.
FFR MK1---Sold
Superformance #884 --- Sold
No more Furds.
11-20-2009, 08:36 PM
NH
With opening the trunk that wide Keep an eye on the external hinges.
11-20-2009, 08:47 PM
what do I need to watch for?
I could reduce the angle by installing the top mounts higher but I don't know if my shocks will support the angle.
FFR MK1---Sold
No more Furds.
11-20-2009, 09:45 PM
OK mike,
I took your advise and re-mounted the top mounts.
Now I need to get stronger shocks which I feel I needed anyways.
Now both my front and rear lids will sit at the same angle.
Dan
FFR MK1---Sold
No more Furds.
11-20-2009, 10:04 PM
Cobra Make, Engine: FFR: 302 w/aluminum heads, Edlebrock injection. Street car trim, no scoop, side pipes or rollbar.
Mikie I think that angle is OK on the purple cars.
"Cobra-Cobra-bo-bobra, banana-fanna-fo-fobra, fe-fi-mo-mobra...Cobra!"
11-20-2009, 10:06 PM
It's not purple, It's Rangoon Blue. A stock ford color from 1957 to 1969
FFR MK1---Sold
No more Furds.
11-20-2009, 10:16 PM
Ahh Rangoon Blue, that was my 2nd guess.
11-21-2009, 07:05 AM
AZ.
Hey Guys,
Ya gotta admit even with all the back and forth that has gone on
" It's Rangoon Blue " is dam funny stuff ! jeff c
11-21-2009, 07:56 AM
Hay,Dan Ratt i've been wanting trunk lid lifters from day one ,But i don't have very good luck when working with a drill around the Cobra as you must of heard .My question to you is how did you do it?. Ill be at 83rd tonight maybe you can bring it over so i can see how you did it.
11-21-2009, 08:44 AM
Rangoon Danr? U dere?
Karlos
11-21-2009, 09:26 AM
NH
Glad you moved the pivot points. The hinges were not designed to be at that angle. They could break.
Don not let Don near any car with a drill. Holes happen.
11-21-2009, 09:35 AM
Or a big e'fn hammer! Or jack stands!
BTW, I've decided to start calling my paint, Rangoon Racing Green.
11-21-2009, 10:09 AM
OK, it's redone and wow It works well.
FFR MK1---Sold
No more Furds.
11-21-2009, 10:13 AM
NH
Much better
11-21-2009, 12:33 PM
Don,
I will show you and get you a parts list.
It is very easy and you will be able to do it no problem at all.
Dan
FFR MK1---Sold
No more Furds.
11-21-2009, 12:42 PM
Don, the job will be much easier, in the garage, with the car up on jack stands or ramps. Be sure to keep the engine running and the struts will work better when you bump the tranny into gear.
Karlos
11-21-2009, 01:10 PM
Famous last words. No problem at all.
AZ Bob
11-21-2009, 01:52 PM
"RANGOON BLUE"? Wasn't that a Chrysler color in the 70's? Same color that they now call Viper Burple?
Dan in Arizona
CCX3209
11-21-2009, 02:49 PM
NH
Ratty,
When I get back from Puerto Rico I'll take a look at your setup.
11-21-2009, 02:59 PM
Making your yearly trek back to the homeland Mikie?
