Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > Shelby American, Inc.
Old 06-16-2010, 06:23 AM
dcdoug's Avatar
Default Suspension coil adjustment ring - locking pin/clip?
Now that I have my cross weights set properly, I'd like to lock the suspension coil adjustment ring in place. Is there a pin or clip for this set-up to lock the ring?
This is kind of a crappy picture (was too lazy last night to jack up the car) , but hopefully it shows the set-up enough to point me in the right direction. Otherwise, I can take better pics soon.
Thanks!
www.partskeeper.com
Old 06-16-2010, 08:46 AM
FWB's Avatar
FWB FWB is offline
what kind of shocks are they? on my QA-1's the have two rings, so you can jam them together to lock....
Old 06-16-2010, 08:59 AM
dcdoug's Avatar
Not sure, need to check, but there isn't a second ring on there now. Putting a second ring on like a jam nut is an option I am considering, but would love a more elegant solution if there is one.
www.partskeeper.com
Old 06-16-2010, 09:12 AM
Shouldn`t be a problem . The two rings lock together and with the weight of the car on them , they won`t turn . On my car , once everything was set , recorded everything , i.e. measure the distance from the bottom of the lock ring to the end of the sleeve on all 4 shocks and record . Also record chassis height , tie rod length etc . Mark the rings and shock body with a marker . Gives a reference if you have a problem or just want to check .
