Old 08-20-2010, 01:15 PM
Cobra Make, Engine: Midstates - 390 FE
Default Separating Two Siliconed Pieces
Hi all. I have a cast expansion tank where the top and bottom are siliconed together and I need to separate the two. The silicone is "super stuck" and I don't want to try driving a wedge between the two for fear of damaging one or the other. I tried heating with a propane torch, but that didn't make a difference. If anybody has any ideas I sure would be grateful.
Drive safe.
Old 08-20-2010, 01:37 PM
Go to the paint store and get a wooden-handled, flat blade scraper, 2" wide or less. Sharpen the edge to a knife point on a stone and work it into the seam. Then push it all around the circumference.
It's my favorite gasket tool.
Old 08-20-2010, 01:52 PM
coosawjack's Avatar
Cobra Make, Engine: Classic Roadsters '66 427 Replica-SOLD
Drive safe.
Rick,
Silicone HATES gasoline......so in a safe place outside just soak it in gas and in will start hollerin' in a matter of minutes........peels off like bad tape!!
NO SMOKIN' WHILE DOIN' IT!!!
Old 08-20-2010, 04:10 PM
ItBites's Avatar
Try monofilament fishing line and use it like a bandsaw blade to saw the RTV between the parts
E. Wood
ItBites
Old 08-20-2010, 06:36 PM
Dwight's Avatar
Smile
("Try monofilament fishing line and use it like a bandsaw blade to saw the RTV between the parts")
E Wood
string will work, flax or nylon
Dwight
Old 08-20-2010, 07:19 PM
392cobra's Avatar
6th Generation Texan
E Wood
Dwight
Even Dental Floss works.
Old 08-20-2010, 08:08 PM
twobjshelbys's Avatar
Dental floss works better than fishing line because it has a texture. Especially the unwaxed stuff.
Old 08-21-2010, 02:38 AM
coosawjack's Avatar
You still have to get it off of the two pieces so a petroleum solvent will still have to be used....kerosene might even work but gasoline is very fast!!
I removed 30 feet of "silicone seam" from the gunwale of my boat with gasoline....piece of cake!!
Old 08-21-2010, 04:36 AM
Silverback51's Avatar
Stick your face between them and Motorboat them.
Never mind. I was confused there for a minute.
John Hall
Old 08-21-2010, 05:07 AM
Whew!! Thank you Silverback,
For a minute there I panicked that 392 and the crew had lost there youthful mirth.
Old 08-21-2010, 07:45 AM
Snakebit's Avatar
Soak it in denatured alcohol.
Snakebit
