Old 08-23-2010, 03:12 PM
Cobra Make, Engine: Venom, BF XR8 260kw, 6 speed auto
Default Ford engines in Cobras
Hi All,
Just wondering if any one has some pics of the footwells used for a 5.4L Ford (BA-BF-FG) engine. I am having trouble getting my head around how much (or little) space is between the engine and the chassis rail.
Nathan
Old 08-23-2010, 03:30 PM
letsboogie351's Avatar
Cobra Make, Engine: Kenmer with Ford Quad Cam Boss 260
Nathan
I don't know what kit you have or if you are doing a scratch build of your own design. However I have a Kenmer with a 5.4 quaddie installed. If you like I will take some pics and try to post them for you
Old 08-23-2010, 05:18 PM
Originally Posted by letsboogie351 View Post
Nathan
My kit is basically rails and a body, so I'm constructing the rest myself. Any ideas and photos would be great, as i'm trying to get my head around the 1300mm ish body and a 800mm engine.
sevenohms AT hotmail DOT com
Nathan
Old 08-23-2010, 05:35 PM
Nathan I hope this helps. You cannot see anything from above the engine. It is too much trouble to pull out the inner guards to take pics so I have some from during the build. The headers sit close to the block. You will notice a triangular section in the chasis just in front of the footboxes. This is where the exhaust exits to go either under the car or through the front guards
Old 08-23-2010, 05:44 PM
Looks good.. what is the dimension you are using for the width of the outer rails (that go under the doors)?? Mine is about 1300mm.
