Old 01-20-2025, 02:23 PM
Cobra Make, Engine: Classic Roadsters Chevy 350
Default Rear LCA and Sway Bar
Tried a search but didn’t have any luck. I have a 8.8 rear and have been considering making some tubular lower control arms / trailing arms since I have gone to QA1 coil overs. Looking for suggestions on how to incorporate the rear sway bar with tubular arms since it mounts to the inner channel of the CR arms. Thanks in advance
Old 01-22-2025, 02:33 AM
Hapnyny's Avatar
Hi,
The good news is the history of this topic is in these archives. Double Venom did a piece on this subject. I ended up purchasing QA1 Lower Control Arms for a Foxbody and had them cut down to size and welded the ends back together. The result of this modification made a big improvement on the rear making it feel a lot more connected to the road and body. Because of this modification I was also able to use a 1 inch adjustable rear sway bar from QA1 as well. If you’re looking for better handling for the street this should help. If you’re looking for better handling on a track you really need to change the 4 link into a 3 link set up. Someone did this once on the forum and I am planning to attempt it this coming spring. Factory Five has a 3 link set up for a straight axle and it looks like it can be fabricated into the CR1 rear.
Old 01-22-2025, 02:35 AM
Hapnyny's Avatar
Hi,
Old 01-28-2025, 11:22 AM
MaSnaka's Avatar
I went to the tubular LCA arms. I do not use the rear sway bar for the reasons you mentioned. I don't miss having it. No over or understeer issues on the street or track. I am still using the front sway bar which is said to be oversized for the car. Very little body roll if any. I remember DV saying to delete both sway bars for better cornering. That he had some much improved results on the skid pad. I wouldn't worry too much about it.
Old 02-01-2025, 08:50 PM
Hapnyny's Avatar
Hi John,
That’s a big piece of information I never found from DB archives. Could you send me the link, O would love to read it?
Old 02-04-2025, 10:05 AM
MaSnaka's Avatar
Hapnyny
Search Classic Roadster sway bar.
There should be lots of old threads from DV and Don Scott.
Good luck
Old 03-15-2026, 06:55 AM
Hapnyny's Avatar
Hey CR67rec,
I had them done recently and the company that did it was Gorman Performance. Ask for Pat and tell him the number 53 car set up is what your interested in.
Old 03-19-2026, 10:02 AM
MaSnaka's Avatar
Looks Good!! Have you had a chance to test it??
Old 03-20-2026, 03:10 AM
Hapnyny's Avatar
My first race is April 19th at Lime Rock Park. The Gorman 4.0 Event. I also just recently purchased the SPC 97260 Mustang Ii Arms Ford Mustang II and installing it next week.
Caster +3.75 +/- .5 degrees
Camber -3/8 +/- 1/8
Toe in +.03 - .06
Vintour XP1 275 35 18
Vintour XP1 295 30 18
Should be a good set up for this season. I also cut the center dash out and got rid of the HVAC System and replaced it with a pod panel with switches.
