Old 04-24-2025, 05:57 PM
Cobra Make, Engine: NAF 427 SC with 429 Cobra Jet motor, toploader 4 speed
Default NAF Cobra sway bar
My NAF Cobra uses the Mustang II front suspension with upgraded calipers/rotors and coil overs. The sway bar that came with the kit (I bought it way back in 1986) is small diameter and I'd like to upgrade to the larger 1" Mustang II bar. Only thing is, the larger bars I've seen look nothing like the bar on my car now. Anyone on here have an NAF and be willing to look at your bar and tell me what it looks like or PM a photo?
Old 05-18-2026, 09:54 PM
Registered User
I don't own an NAF, but dealing with older Cobra kits, you'll often find the sway bars were proprietary bends. Trying to find an exact visual match from a standard Mustang II catalog might drive you crazy.
Your best bet might be measuring your current bar (overall width, arm length, and the distance between the frame mounting points). Then check out somewhere like Speedway Motors or call up Hellwig. They sell universal splined sway bars or adjustable kits where you can basically build it to fit your exact dimensions.
Old 05-21-2026, 09:55 PM
Exclamation
Used to be that every town had a spring shop... maybe not so much anymore. If you are near a bigger city, you might have a few shops still around. They could make you a copy with the 1" diameter. Might be worth checking around...
Paul
Unique Motorcars 289 USRRC
1964 289 5-bolt block
Toploader and 3.31 rear
Old 06-02-2026, 10:35 AM
Cobra Make, Engine: shellvalley 428 ford
There are numerous 1 inch front sway bars listed on the internet that look like the
original Mustang II bars
