Old 03-22-2026, 09:33 AM
NoVA Cobra's Avatar
Cobra Make, Engine: SPF1439 427FE s.o.
Default Superformance Cobra mkIII rear end rebuild
So I need to pull apart the IRS rear end to do my gears. While it's out, I may also do all bearings and cv joints. The question - what are the steps in taking this Ford 8.8 IRS out of a Superformance - pulling the hubs and cv joints then dropping the rear? I've already pulled the calipers and ds - now looking to pull hubs and cv axles. I figure I need to get that spinner adapter hub off to remove the axle nut. I just started with the 12mm hex bit to remove the nut/pins on the spinner adapter hub. What's the secret to getting these off without ruining the nut/pins?
Superformance 1439 w/427FE side-oiler. 2007 GT500 40th Anniversary CSM07XL0078. 2007 GT500 40th Anniversary CSM07XL0085.
