Old 05-25-2004, 08:27 PM
Fitz's Avatar
Cobra Make, Engine: FFR Mk 3 408 530 - 585 T- mustang Dyno at B&R
Default Anybody done a 514
I thought it would be nice to ask if anyone has done a 514 and let them tell what it resulted in. I have read too much comparison data and I am confused. It gets down to "what will you be happy with; what am I going to use the thing for; am I going to race; weight v cornering etc. I want the big boy but I want to use pump gas, not race gas unless I go to the track. If someone actually did put one of these babies in their car, I would like to know what not to do.
Old 05-25-2004, 09:56 PM
Back in Black's Avatar
Cobra Make, Engine: West Coast. 514 / 6 speed Richmond overdrive
Lightbulb Seems you have a misconception...
The 514 has BIG "lungs" and VERY low compression.. mine runs on pump regular.. in fact premium is too much....it does not like it
Real world compression is 8.9 to 1 (subtract 1 for the aluminum heads)
James Madison, father of the Constitution, said, "If Tyranny and Oppression come to this land, it will be in the guise of fighting a foreign enemy." He also said, "No nation could preserve its freedom in the midst of continual warfare..."
http://www.standdown.net/index.htm
Old 05-26-2004, 03:41 AM
Tom Wells's Avatar
Hello Fitz,
If you use the Search selection at the top of this page with "ford and crate and motor" or something similar, you would come up with results like this:
Crate motor thread
Old 05-26-2004, 06:01 AM
Cool Tom...
My motor is dyno-ing today or tommorrow.. with the carb for break-in... then after I get her road-worthy a mechanic buddy and I are going to install the Holly EFI system.. then will truck her to a specialty shop north of here for chassi dyno and tuning.. they know all about the pro-jection system and have their own software ready.. they will be spending an entire day tuning her...will report on results when it's done!
Old 05-26-2004, 08:12 AM
Fitz, there are many 514s installed in Superformance cars. Their owners are pretty vociferous on the SCOF forum. It's a great motor. If I were to replace my 460 that's the way I would go. I have an old 1972 short block bored a bit and 10 to 1 compression with a 114 degree cam lobe separation (not "lopey") and not radical cam lift and duration. My motor can run all day long on pump premium. The new 514 with the SCJ heads rated at 550hp has 110 degree (lopey) but should hold up fine. I get 15 to 17mpg on trips.
Old 05-26-2004, 10:18 AM
Cobra Make, Engine: West Coast Cobra weber fuel injected 557 C.I.. 800H.P 760LBS. TQ. Magnum T56
Send a message via AIM to MAXVELO
Default OH YEA, 514!!
Mine seems to be as bulletproof as the 302. Of course I dont need to beat on it to get going. Just Idling it hauls Balls! Does anyone know who makes the biggest hydraulic cam for this block? This winter I plan on adding another supercharger to the other side and run them both through a MONSTER intercooler.
WHEN YOU HAVE MORE HORSEPOWER THAN YOU NEED ITS STILL NOT ENOUGH!!!!!!!
