Go Back   Club Cobra > Engine Building, Tuning, and Induction > 429/460 Engine Talk
Old 11-20-2009, 09:56 PM
JA COBRA's Avatar
Cobra Make, Engine: superformance 460/ stroked to 521
Default Timing chain cover
I was trying to take off my water pump housing to send out and get polished. While i was trying to pry it off i cracked the top of the timing chain cover.Now i have a huge job to chang it or am i wrong,from what i see there are alot of different covers,what do i look for so i can order the proper one?
Old 11-20-2009, 10:26 PM
Cobra Make, Engine: Heritage body, built the rest..460 Toploader..9"
Default Timing cover
I don't think it's a huge job...You already have the w/p off. Just a few more
bolts, then the harmonic balancer and a few pan bolts across the front and a couple down the side should allow you to remove it. As far as a replacement, they are available new on e-bay, I purchased one for mine it is a quality piece. It fits 429/460...It comes with dipstick tube installed and blockoff plate if you're not using a mechanical fuel pump. Price was around $70.00
6year Heritage A&F
1969 Hurst SC/Rambler(only 1,512 made) in the middle of restoration.
Old 11-21-2009, 06:02 AM
Silverback51's Avatar
Depending on the mileage on the motor, you may want to consider changing the timing chain and gears.
John Hall
Old 11-21-2009, 07:20 AM
JA COBRA's Avatar
Motor has 11500 miles do you think its worth changing?
Old 11-21-2009, 04:56 PM
When you have the cover off, just check it.
I always tend to be conservative. As long as it's apart, I would replace it. It does not have that many miles, but you have to consider how you drive it. If it spends a lot of time near the redline, then it will stretch more than if you take it easy all the time.
John Hall
Old 11-21-2009, 08:26 PM
JA COBRA's Avatar
Thanks for the info ,i will check it when i get the cover off.I am waiting for the puller to get the balancer off.
