Old 03-09-2010, 11:53 AM
Cobra Make, Engine: FFR 30K mile driver
Default single/dual plane intake
Is a dual plane a more streetable intake. It is a vic jr with 650 holley on vic jr heads. With the nasty cam it does not like 1600 or lower when getting on it. You know that hesitation. Have a half inch spacer also. Just wondering if i can put a piece of aluminum in the intake and make it adual plane so it works better for the street. Any ideas would be appreciated.
gary
Old 03-09-2010, 12:07 PM
FWB's Avatar
FWB FWB is offline
dual plane is more streetable.....
Old 03-09-2010, 12:15 PM
Ron61's Avatar
Post
What FWB said. The dual plane gives you more low end torque. The single plane is more of a racing type. I have ran both types and the dual plane is far better for normal driving plus it also works well if you are not all out racing.
Ron 61
Ronnie Widener
View my Miscellaneous Gallery
Old 03-09-2010, 12:19 PM
joyridin''s Avatar
Unless you run in the upper RPM range all the time, try to find something like an Air-Gap style intake. Kind of the best of both worlds. Has a wide torque range with a decent upper limit, plus it is pretty streetable.
Old 03-09-2010, 12:30 PM
It also depends on the size of the engine as well. A Victor Jr. on a 351W will have different results than a 427W with a Victor Jr.
If your cam doesn't like to be pulled down that low, it may not help things to mix a wild cam with a dual plane street intake. That would be a mismatched combo.
What size is the engine? What are the cam specs?
Also, hesitations can be tuned out as they are generally because of a lean situation.
Old 03-09-2010, 01:20 PM
The engine is a 347 stroker. Cam specs are adv dur of 286, dur @.050 of 230, lobe sep of 110.0 and lift of .598. A comp cam. I really do not want to change cams right now, maybe this summer. My goals have changed so a milder setup is probably best. Currently dynoed or 2 yrs ago at just under 480 at flywheel. Seems high but is a nasty rumble. Also, no choke on carb.
Txs gary
Old 03-09-2010, 01:21 PM
That cam shouldn't be that wild. I think an RPM Air Gap would suit the engine well. If you're having hesitation issues, it's most likely a carb tuning issue.
Old 03-09-2010, 01:29 PM
X2-what Brent said.
Chas.
Old 03-09-2010, 01:42 PM
CobraEd's Avatar
The lift is very high for that mild duration. I have not seen that cam listed. Is it custom from Comp Cams?
________
________
Old 03-09-2010, 02:27 PM
FUNFER2's Avatar
(high lift) ? It looks like that's "advertised" duration.
Kevin
Old 03-09-2010, 02:36 PM
A 35-450-8 or a 286H-R10 by comp cams
Old 03-09-2010, 02:59 PM
CobraEd's Avatar
That must be one of the two versions that Comp Cams makes specifically for the stroker 302 (331/347). I have seen them in Jegs.
With 286 total duration and .598 lift. I still believe that is a lot of lift the that small amount of duration. However, if it works, it works. Just hope it lasts. With that lift to duration ratio, it can put a big strain on the valves.
________
________
Old 03-09-2010, 04:06 PM
Cobra Make, Engine: jbl
you're out of the rpm range with the cam. wait till 2000+rpm til you get on it, or fix the tune, or remove the spacer, or change the manifold. lot of variables here. i would do the easiest first though. o2 sensor and gauge setup could tell you a lot about the hesitation.
Old 03-09-2010, 04:16 PM
FUNFER2's Avatar
A lot can be done with just tunning to what the engine wants. Do you have a local business that has a chassis dyno, and a well trained mechanic, and not just a computer geek ?
Kevin
Old 03-09-2010, 04:32 PM
Bernica's Avatar
Senior CC Premier Member
If I'm not mistaken, there is more of a difference between a single and dual-plane manifold besides just adding an aluminum separator. I may be wrong. If so, I'm sure I will be corrected. Agree with others above on other points.
Old 03-09-2010, 04:36 PM
i was going to add what gear is this occuring?
Old 03-09-2010, 04:40 PM
Don't get me wrong about this engine. It is one bad engine. When I nail it i better grab a gear or i am to late. Have only been into the secondaries a dozen times. Thru third gear is a kick even with granny shifting and a 6 k rev limiter bug in. Definitely has the old style lope of a roller. Just what i wanted when i asked gordon what he thought. My wants have changed is all. Had a 6.5k limiter in it at first and never nosed over.
gary
Old 03-09-2010, 04:42 PM
CobraEd's Avatar
The whole design is different. You can put a divider in a single plane manifold, but it is a band-aid solution and not the same as a true dual plane manifold.
________
________
Old 03-15-2010, 06:10 PM
The RPM Air Gap dual plane would be the way to go on that engine,for excellent torque/power in the real world of street use.
Don't put a divider in the single plane intake. I had one break loose,after 6 months use,and it cost a block!
Old 03-16-2010, 06:05 PM
few ideas
You could advance the cam a few degrees (depending on where it's installed now).
Try adding some base timing and shorten the curve to compensate - this usually improves idle and low end.
As noted a surge or lumpiness at part throttle is often a fuel curve issue that can be tuned out.
I've tried a bazillion different intake inserts, stuffers, and spacers on the dyno. Most do nothing. A very few seem to help - but they're never predictable.
Survival Motorsports
"I can do that....."
2008 - 429 cid FE HR - 675HP
2007 - 429 cid FE MR - 659HP
2006 - 434 cid FE MR - 678HP
2005 - 505 cid FE MR - 752HP
