Old 08-26-2010, 11:54 AM
Default oiling system mods
Most people recommend installing screw in oil gallery plugs instead of the press in plugs for safety.
Also on some Mopar engines it seems common to drill a small hole in a plug behind the distributor gear in order to provide adequate oiling for the gears.
I've seen some people recommend this for the sbf too. Makes sense to me, especially when using a roller cam.
Are there any known drawbacks?
The one to drill would be on the left:
What screw in plug size fits the bores?
Simon
Old 08-26-2010, 12:04 PM
Rick Parker's Avatar
3/8" pipe plug
Old 08-26-2010, 02:54 PM
DAVID GAGNARD's Avatar
Simon
Yes the one on the left in the photo, with the block upright, it's on your right and I drill a .015 hole in the center of the plug,it'll shoot a small stream of oil on the backside of the timing gear, keeping everything lubed......been doing that for sometime now....
DAVID GAGNARD
Old 08-26-2010, 05:48 PM
bobcowan's Avatar
Although I don' really see any advantage to it, I can't see that it would hurt anything. AFAIK, there are very few people doing this to SBF's. And yet, I almost never hear of an early timing chain/gear failure.
Old 08-26-2010, 05:49 PM
CobraEd's Avatar
If you don't drill the hole, then how does it get lubed from the factory ????
________
________
Old 08-26-2010, 06:13 PM
I'm guessing splash lubrication..........
I can't remember exactly, but I've seen this on a number of factory engines,chevy's if I remember right.........
DAVID GAGNARD
Old 08-26-2010, 06:16 PM
I've seen it on BBC's.
On Fords, I don't do it, I just tap the galley plugs for threaded plugs. The timing chain should get lubed by oil splash.
Old 08-26-2010, 07:30 PM
It actually squirts on the distributor gear, not the chain.
Old 08-27-2010, 01:34 AM
There seem to be lots of problems with premature distributor and/or cam gear wear when using a roller cam. That's why I'm thinking about this.
My idea was to drill the plug at an angle so the oil will squirt directly on the meshing gears as shown in this sketch:
I hardly found anything about this modification on the internet, that's why I wanted to hear some opinions.
Old 08-27-2010, 04:59 AM
The galley plug your talking about is a plug on the oil galley that feeds the lifters. I don't think it has anything to do with the cam gear and distributor gear, drilling the hole in it will shoot oil on the backside of the upper timing chain gear, the splash from that will lube where cam gear/distibutor gear mesh....otherwise, the cam gear/distibutor gear are lubed from the oil slinging off the crankshaft at the #1 journal....
I'm not sure you could drill the hole at enough angle to directly shoot oil on the cam/ditributor gear...
It can't hurt to do it though and I do it on my engines just for adding oiling....
DAVID GAGNARD
