Old 11-03-2010, 04:15 PM
Send a message via MSN to CowtownCobra
Default Busted rocker stud
Broke an exhaust rocker stud up at the start of the threads for the adjuster (hydraulic roller). At first glance nothing else seems wrong. Valve appears to be fully closed and not bent. Engine has about 14k miles on it. I just can't understand what would cause it to break. Might be a manufacturing flaw, or it might be ????
Old 11-03-2010, 09:19 PM
bobcowan's Avatar
Check the others for signs of contact.
.boB "Iron Man"
NASA Rocky Mountain TTU #42
www.RacingtheExocet.com
Old 11-03-2010, 11:20 PM
Hi bobcowan. What shall next thing to do after checking the other signs of contact? And if there is no other signs of contact, what shall do?
Old 11-04-2010, 05:52 AM
Z-linkCobra's Avatar
Cobra Make, Engine: Everett Morrison, All aluminum small block ford.
So Im assuming the stud broke in between the adjuster and the rocker? Allowing the rocker to come off obviously. Does it look like it was broke off to one side or another...or does it look like it was pulled apart?
Check both contact points on the tip of the rocker, valve end as well as pushrod end. Any signs of damage?
Could be it was just a faulty stud. I cant imagine you having a clearance issue after 14,000 miles..but you never know.
" If it wont break em loose in 3rd gear, it aint enough power "
Old 11-04-2010, 10:40 AM
bobcowan's Avatar
Then I would install a new set of rocker studs and drive on. KC has a reputation of using quality parts. But if one broke, I would be worried about the others every time I turned the key. Rocker studs are cheap, and the job is easy.
.boB "Iron Man"
Old 11-05-2010, 10:04 AM
Rocker studs whip like spaghetti.
Put a girdle on it.
Old 11-05-2010, 11:00 AM
zrayr's Avatar
Cobra Make, Engine: Fords
may be worth the expense of going to 7/16" studs and rockers. They are considerably more stiff than the 3/8" variety
Z.
'65 K code Mustang
'66 Galaxie 500
Old 11-13-2010, 11:08 AM
HeadDoctor's Avatar
2 Things are consistent here
1) Like mark said the the studs move around a lot - In fact the entire valve train looks like spaghetti when viewed on the stroboscope with engine running
2) It takes about 370 to 400 lbs of open pressure to control the valve train with a good hyd roller
3) Consider changing the studs to 7/16ths and putting a stud girdle on it you may have to get taller valve covers
Innovation is the key to power and speed
The smartest thing I ever said was I Don't Know
