View Poll Results: What shaft mounted rockers would you choose?
Harland Sharp 1 7.69%
Jesel Sportsman 7 53.85%
Doesn't matter; both are up to the job 3 23.08%
None of the above; they're too weak! 2 15.38%
Voters: 13. You may not vote on this poll
Old 11-19-2010, 01:02 AM
Caprimaniac's Avatar
Default Any input on what shaft mounted rockers to use?
For a 347 with Victor Jr. heads; which of the three options would you pick?
Please VOTE!
The new shaft mounts with stainless steel rockers is my favourite, although in the adds there is much focus on top fuel and "really harsh" racing environment for these rockers.
I'm currently using the Comp Cams stainless steel roller rockers on 7/16 studs, and it seems to work very well.
Will any of these aluminium rocker options be a good choice, and is there anything that makes one better than the other?
Post this poll simply because I have no 1. hand experience on shaft mounts and have few others to ask, besides from you, great lot! Use is mild solid roller cam (0.64" lift, 300 duration, up to 7500- 8000 rpm). did some searches and read quite alot without finding a favourite amongst the two poll options. Last list of parts I used were simply put together by manufacturers choice and my own eyes staring at the the glossy catalogue pages...
RS
Old 11-19-2010, 01:53 AM
Hotfingrs's Avatar
I use T&D shaft mounted system, and have been for about 6 or 7 years now. At the rpm's I turn, I don't want to worry about twisting or any other rocker problems.
Jack
XSSIVE .....
Old 11-19-2010, 04:28 AM
T&D or Jesel.
Old 11-19-2010, 09:52 AM
Please VOTE!
RS
A...Do NOT use anything form China with a bearing in it.
B. Mine, Harland Sharp, T+D, Jesel..they are all more then serviceable.
If you're not racing it, what do you intend to gain by changing what works well already.
If you are racing it....consider a stud girdle.
Old 11-23-2010, 01:34 PM
Earl J's Avatar
Cobra Make, Engine: GT350,289 w/48IDA Webers
Send a message via AIM to Earl J
T&D
~Earl J
Earl J Castillo
VP NorCal Region SAAC 2012
Old 11-23-2010, 04:57 PM
zrayr's Avatar
Cobra Make, Engine: Fords
a big block Ford engine will turn over considerably easier by hand than a small block. The difference is the increased friction of the small blocks rocker arm system over that of a big block. Even a non race engine will benefit from the "free" horsepower from the friction reduction of a properly designed shaft rocker arm system.
Z.
'65 K code Mustang
'66 Galaxie 500
Old 11-26-2010, 01:11 AM
Maurice Butler's Avatar
Cobra Make, Engine: Scratch build, with help
unless you replace the bearing with a quality bearing thats not made in China
Maurice
researching for scratch build
Old 11-29-2010, 09:35 AM
I make shaft rockers, though I am dropping (selling, really) the product line.
Bearing press is critical. Unless you have the capability of sizing the hole accurately. If you can't, you are asking for real trouble. And, in my experience, the Chinese can make a hole any size you'd like. They can not, however, do it twice in a row.
Old 11-29-2010, 09:37 AM
Z.
So, a roller in a shaft setup, rolls easier than a roller in a stud mount.
Very well, then.
Old 11-29-2010, 04:07 PM
Frank Messina's Avatar
Z.
I have to disagree. That only holds true if you're speaking about the factory stamped rocker arms. When you move into the high quality stud mounted roller rocker realm all bets are off. The only possible advantage might be high RPM stability under high spring loads but not even that is a slam dunk since a good stud girdle can take care of most any flexing issues. I used to run my drag race motors to over over 8000 RPMs with Crane rockers and a Ridgeway stud girdle with no complaints from the valve train. What will make an engine hard to turn over though is heavy valve spring pressures which is likely what you'll encounter in a high revving race motor vs a more sedate hydraulic cammed boulevard cruiser.
Frank
FFR - V8, Manual Trans, PS, Inop Wipers, No Radio, Gas Mileage so-so
Old 11-29-2010, 04:49 PM
zrayr's Avatar
Originally Posted by Frank Messina View Post
I have to disagree. That only holds true if you're speaking about the factory stamped rocker arms. When you move into the high quality stud mounted roller rocker realm all bets are off......."
I'm willing to bet a 6 pack of your favorite brew, that with similar valve spring pressures, a 289 or 302 with the spark plugs out & with a flat tappet cam & roller rocker arms will be harder to turn over by hand than a 427 engine with the plugs out & with a similar non-roller camshaft. The difference won't be as much as with a small block with the stamped rocker arms, but the BB will still turn over easier.
Z.
'65 K code Mustang
'66 Galaxie 500
Old 11-29-2010, 07:29 PM
Zoom This's Avatar
Well, for what it's worth I have had Crane shaft mounted alum. roller rockers for 5 years and 8k miles. No problems whatsoever. Hydraulic cam, .565 intake lift on a 418W. Track race, street race, still good shape top side.
Old 11-29-2010, 09:07 PM
zrayr's Avatar
just curious, what heads are you using ? I used to live up near you (Silverdale, WA) and still miss it 17 years later. Hope you made it thru the blizzard OK.
Z.
'65 K code Mustang
'66 Galaxie 500
Old 12-23-2010, 02:00 AM
Default Outcome
Finally I settled with Jesel's.
Although, after timing the cam correctly and checking piston to valve clearance, I figured I could have ran 1.7 ratio exhaust- I was then tempted to go with Crower (which are even more expensive...) . But then a person talked me into sticking to the 1.6 ratio. Maybe a mistake. (Because the cam is symmetrical; lift & duration same on in and ex. And I stick to the theory that this engine will do better with a little more on the exhaust side....) And I also figured ot that the SS Crower parts were not more expensive than their aluminum stuff... Well; I will have to get an assymetric cam next time.
Thanks for input
Old 02-16-2011, 01:52 AM
Default Is this why they're called roller ROCKERS?
As one can clearly see, the rocker stud has been eaten by the rockers.... This isn't the worst example. How long will it take to break one of these studs by the ROCKING action by the rockers? I'd guess there were 0,5mm missing from the stud, in a ring- shaped pattern around the circumference.
Also, the rocker have clearly touched the valve retainer. Although when thesting on the work bench, the clearence is 2-3 mm.
Hope the pics are shown this time.
RS
Old 02-16-2011, 03:05 AM
Default Easy back a little RS
caprimanic Before you get crazy on this, I have seen this before with windsor motors.
6 things cause this, There is too much clearance between the stud and the rocker. sloppy in the hole. There was no stud gridle to control the rockers and stablize the studs. How many times was the motor banged off the rev limiter? Poor oiling between the trunion and the stud.The wrong pushrod length. You also have the rockers hitting the springs, see the 2 marks on the under side. I think going back through the geometery of your valve train is needed. It looks like not enough clearance. Like to see the other rockers on the under side too. What was the coil bind on this?
From the pictures, I am going with over revving and banging a limiter. Valves banging rockers and cause deflection.
You might also want to recheck the valves, some of the stems have a wierd wear pattern on the shafts. Looks like the chrome is being worn off. Rick L.
Old 02-16-2011, 03:09 AM
Check your valve guides for wear while you're looking things over.
Under very high rpm loads, parts will move all over the place. Rocker studs will deflect, rocker arms will deflect, valve guides will start to wear in one spot, etc. The combination of all of these will cause the problems that you're seeing. Everything is dancing around and moving and the areas where you had clearance before may not have clearance anymore.
I'd say your problem will be solved with your shaft mounted rocker arm setup.
I'd pop the valve seals off and do a quick "wiggle" test on the valve guides...
Old 02-16-2011, 03:13 AM
Rick,
He has admitted in previous posts to turning (or trying to) this engine to 8000 rpm on many occasions.....therein lies the problem....
Parts do weird things at higher rpms without proper reinforcement and blueprinting....he's seeing the result of that.
The valves do look worn, that's why I told him to check the valve guides. With all of the wear on the parts, I'd say the guides are catching the brunt of it.
Old 02-16-2011, 03:22 AM
Default You are the man
blykins Brent we both have seen this for many years. He's liucky to not have a motor in his lap with this kind of abuse. Over revving and everything got smacked. Have a good one. Rick L.
Old 02-16-2011, 05:01 AM
What's a rev limiter??
Yes, yes- I see all your arguments help explain the result here.
Been thinking of stud girdle and rev kit, but hope lighter valvetrain & shaft mounted will do the trick. Yes, I'm also putting in a rev limiter. (But what should I dial in??? The knob goes all the way to 10.000....)
Be seeing you for future, highly appreciated, discussions.
