Old 12-10-2010, 06:03 AM
bingo2's Avatar
Cobra Make, Engine: RUCC, SB 331 Stroker
Default Intake Manifold Gasket
I have a 331 stroker with Brodix ST 5.0 R heads and an Edelbrock RPM Air Gap intake manifold. There is a very small leak in the intake manifold gasket around the #2 cylinder and I'd like to replace the gaskets.
I've read some not so flattering remarks about the Fel-Pro gaskets recently and I'm looking for replacement recommendations.
Ken
Old 12-10-2010, 07:17 AM
Calbullet's Avatar
Cobra Make, Engine: Superformance 460 SVO
Ken, use the Victor Reinz gaskets or get the Fel Pro with the steel shim in the gasket.
Old 12-10-2010, 08:04 AM
SunDude's Avatar
I went with the steel-core gasket from Fel-Pro on my 392 (351W). So far, so good.
Old 12-10-2010, 08:21 AM
bobcowan's Avatar
I use the plain Fel-Pro gaskets, and have never had a failure. Ever.
.boB "Iron Man"
NASA Rocky Mountain TTU #42
www.RacingtheExocet.com
Old 12-10-2010, 11:32 AM
Just stay away from Printoseals...
Mr. Gasket is good, SCE, Corteco, etc.
Old 12-10-2010, 04:50 PM
McD00's Avatar
Cobra Make, Engine: 931 mangled in parkinglot incident - traded for new house roof <sob>
Mcvette
"...Just Shut the phuque up and Move on please..."
Old 12-10-2010, 05:36 PM
wrogers55's Avatar
Cobra Make, Engine: Backdraft #318, 418 CI, 532 RWHP, Mass Flow Injected, TKO600-Road Race, BMW M3 Suspension, Race Springs (Wouldn't do it again, rough on the street).
Plus one for Hylomar Blue, Racing Formula. You could use a newspaper gasket with the stuff and be fine. SCE would be my choice. Just did the same thing.
Wayne Rogers in Hideaway, Texas
Old 12-10-2010, 12:56 PM
bingo2's Avatar
Thanks to all who replied.
Old 12-10-2010, 01:21 PM
zrayr's Avatar
Cobra Make, Engine: Fords
use some Hylomar with the gasket of your choice & it is doubtful you will have any leaks. It is non-hardening. You can get the Hylomar racing formula anywhere that sells Permatex.
http://www.permatex.com/products/Aut...ge_Sealant.htm
http://www.hylomarsealant.com/_resou.../products.html
Z.
'65 K code Mustang
'66 Galaxie 500
Old 12-11-2010, 11:08 PM
Rwillia4's Avatar
I don't think I would want to use a steel shim gasket on an aluminum head and intake. It will "dent" the aluminum and the next replacement will be more difficult.
Old 12-12-2010, 07:04 AM
zrayr's Avatar
you might have a point there if the bolts were torqued to head gasket levels. Depending on the manufactures instructions intake bolts are usually tightened to only 17 - 25 ft. lbs. Would that be enough to dent the aluminum?
Z.
'65 K code Mustang
'66 Galaxie 500
Old 12-12-2010, 09:03 AM
wrogers55's Avatar
Interesting conversation with the AFR head guy when I was getting an intake gasket recommendation. He says to not use a torque wrench on the intake bolts (we went through all of AFRs reasoning).
They just want you to "snug" then up good and firm and then consider them a maintenance item and recheck when you nut and bolt, without retightening those still snug.
But, in the end, I always torque them anyway. At 15 lbs into those aluminum heads, it starts to feel like plenty and more seems like asking for trouble.
Old 12-12-2010, 09:16 AM
bingo2's Avatar
Since I'm a lazy SOB, I thought I'd check the torque on the intake bolts before replacing the gaskets. Torqued them to 18 ft. lbs, in three stages; 10, 15 and finally 18, it was definitely needed.
I'll fire it up tomorrow morning and check for leaks again.
Old 12-12-2010, 12:21 PM
Snakebit's Avatar
I have AFR heads. Torked the intake bolts to 18 lbs with a little oil on the threads.
Snakebit
