09-08-2011, 09:23 PM
Cobra Make, Engine: FFR
Rousch #1, no doubt dyno numbers are mainly a tuning guide. Mustang dyno's usually read lower than a dynojet, but at least they are rwhp ratings. Flywheel hp ratings don't take into account drivetrain loss, much less loss from sidepipe restriction. Look at the Daytona Coupe replica's, they get killed on rwhp due to sidepipe restriction. A better measure is mph in the 1/4, that will usually give a better guide of what power a combo is making. Cheers.
09-08-2011, 11:25 PM
Originally Posted by AL427SBF
Thought it would be nice to see what kind of power the small block guys are getting these days. If you are one of them and don't mind sharing I would be curious to see what the range in HP & Torque is. Filling out the table below will help put it all in context, thanks for your input.
Other: Anything else "trick" you have above and beyond a street performance motor.
Displacement: 369
Block Type: Dart
Compression Ratio: 10.5
Caburetor Size/EFI: massflo efi tb
Peak Crank HP @ RPM: 435 rwhp
Peak Torque @ RPM: 512ft/lbs @ wheels @ 3000
Trick Flow fac 190 heads, tko 600 road race, 9"diff 3.7:1 posi track lsd. Michelin slicks 27/65/18 & 30/65/18 1200kg street registered.
09-09-2011, 06:03 AM
As far as dynos go, might as well get it done right which is part of the tuning process. Many*different types of dynos out there, but only one gold standard (my opinion) - the Dynapack*4000. Just bolt the rear hubs to those tightly calibrated servos,*read your exhaust gasses during pulls, and*adjust the ignition and fuel delivery system for absolute optimum performance across the RPM range.
09-09-2011, 08:12 AM
09-09-2011, 07:17 PM
402w
my 402w made 562HP and 535 ft lbs of torque under 6000 rpms...
09-09-2011, 09:20 PM
Originally Posted by JEwalt
They want $40,000 it is all aluminium, they dont have any yet, and it will only be sold through Dendeste. Looks cool.
PRIDEnJOY
09-10-2011, 03:42 AM
Makes sense, down the road I may look into a "small" supercharger setup. Not a dedicated fulltime unit but something I can turn-on if I want a kick in the pants. Don't know they even make such a thing and it would have to be SMALL so as to fit under the hood and pull from the stock scoop. I think Mel Gibson had that setup in his Police Persuit mustang? in Mad Max. Always liked the idea of hitting a switch to spool that baby up. Probably not the best bang for the buck either, added weight and a parasitic drain until you're spun up.
Mel's car actually is a XA-XC Falcon Interceptor Coupe. Look up Australian Fords for a bit more info. I understand that there are quite a few in the States
Rog
Rog 246
Harrison #100
09-15-2011, 04:32 PM
SBF specs
Displacement: 347CI
Block Type: Ford Boss 8.2 deck
Compression Ratio: 10:1 +/-
Caburetor Size/EFI: 750 Barry Grant RR Demon DP
Peak Crank HP @ RPM: 482@6300 (avg 384 from 3500 - 6600)
Peak Torque @ RPM: 430@5300 (avg 414 from 3500 - 6200)
Basically took a new Ford Racing 450hp 347 and dropped at my engine builders shop. Complete blue print, about 5 hrs short turn radius work on heads, port match and cleanup. True decks to give comp a slight bump. Reassembled with all original parts with exception of Melling Select pump, MLS head gaskets and Aviaid GT40 pan. Very mild tune running right at 12a/f with 35 degrees timing all in by 3200 rpms. Water temp 178, oil temp 190. No doubt we could have gotten to 500hp if we leaned on it a little more.
5000 trouble free and fun miles since build completed in July 2010.
Currently building 363ci using basically same parts with exception of h-beam rods, internal balance, higher quality pistons, 11:1 cr and mid level solid roller. Hoping for 550-575hp with a usable RPM range up to 7200. Considering new Edelbrock XT FI for this engine.
High revving small blocks are a blast in these cars.
09-15-2011, 05:12 PM
Smalls blocks rule road racing and now with turbo charging being so effective they run the strip also.
PRIDEnJOY
09-15-2011, 05:19 PM
KY
Force fed small block horsepower = naturally aspirated big block horsepower.
09-15-2011, 06:30 PM
You do have a good point.
PRIDEnJOY
09-15-2011, 07:09 PM
Isn't that what David said to Goliath before the **** hit the fan?
11-19-2011, 12:00 PM
OH
The supercharger on Mel's car was not real. Was a hollowed out blower witha pulley for looks.
11-21-2011, 06:40 PM
NC
Cobra Make, Engine: Factory 5
This is the writeup of my engine that came with the car.
It is a built 302 bored .020 over and makes a dyno tested 331hp at 5900 rpm and 324ft./lb. of torque at 4500 rpm. The machined block is equipped with a balanced rotating assembly complete with SRP forged flat top pistons and shot peened connecting rods. Next, a Comp Cams XE274HR camshaft and Air Flow Research 185cc aluminum heads with Comp Cams roller rockers were bolted up. Then an Edelbrock Performer RPM intake topped with a Holley Street Avenger carburetor finished things off. An MSD ignition system complete with both an MSD distributor and MSD coil provides the spark.
The trouble with retirement is that I never get a day off!
12-23-2011, 07:59 AM
Ga
Cobra Make, Engine: FFR with Dart Iron Eagle 408w motor with AFR 225 heads and 83mm turbo, 924rwhp, 986rwtq
Dyno tune with Steve Petty.wmv - YouTube This is my dyno video of my turbo charged FFR / 924rwhp/ 986rwtq at 18 psi
12-23-2011, 08:05 AM
Ga
Displacement: 408w
Block Type: Dart Iron Eagle
Compression Ratio: 9:1
Caburetor Size/EFI: 120 #/hr injectors
225 AFR race heads, 83mm BW turbo with race cover 18psi = 924rwhp / 986rwtq the car is now making 22-23 psi http://www.clubcobra.com/forums/pict...pictureid=6856
12-23-2011, 11:43 AM
I love the 120 pound injectors, mine are 46  .
PRIDEnJOY
12-23-2011, 01:00 PM
AL
408 w
I picked up a 408 from Keith Craft yesterday to go into a B&B Cobra. 531 hp at 5700 and 540 tq at 4300.
Great street motor.
Dwight
12-26-2011, 03:43 PM
MD
Cobra Make, Engine: Ford 289
My engine numbers
Displacement: 333 (331 w/.040 bore)
Block Type: 5 bolt 289
Compression Ratio: 10.6
Caburetor Size/EFI: 680 Holly XE
Peak Crank HP @ RPM: 392 @ 5900
Peak Torque @ RPM: 401 @ 4200
Other "trick" parts:
custom cam, TW 170 heads, TRY-Ys, Eddy performer RPM, custom curved distributor, 2.5" exhausts, Jacobs ignition.
My numbers are RWHP and RWTQ based on chassis Dyno results. This build makes 17" of vac and is very happy, idling at 900 Rs.
Merry Christmas all!
Ken
Severna Park, Md
