Old 12-25-2011, 11:47 AM
Cobra Make, Engine: SPF-small block stroker
Default Air cleaner clearance
I have decided to ditch the S&H aircleaner and turkey pan, and go to a more efficient set-up. I have an SPF with a 351 block, and an air gap intake. I would like to use the large oval Ford racing aircleaner, I think it's 21"X10", by 2" or 2 1/4" high. I don't think there is a clearance issue, but if someone with the same or similar set up could advise me before I order the thing, I would appreciate it.
Thanks, xcop
Old 12-25-2011, 07:47 PM
Cobra Make, Engine: spf 2489 kc 427
I have that setup, it fits.
Old 12-25-2011, 08:07 PM
fordracing65's Avatar
Should fit, spf bumped up there hood for differnt size engines, height.
PRIDEnJOY
Old 12-26-2011, 11:40 PM
Thumbs up Thanks guys
for the information. I looked at Hollley 14" X3" with a 1 1/4" dropped base, but I wasn"t sure. I need to get the car over to the house, so I can do some measuring, but with the crummy weather, I have just left it in storage for now.
Old 12-27-2011, 06:53 AM
dont's Avatar
Cobra Make, Engine: SPF #1235
Thanks, xcop
I have a 460 with a Victor single plane intake, one inch drop base, and am using this air cleaner with a K&N filter. It amazed me that I only lost eight HP on back to back dyno pulls with and without the air cleaner.
Superformance #1235
460/T5
Old 12-27-2011, 07:08 AM
gsharapa's Avatar
The other consideration is a dropped base. This was a Superformance I had about 6 years ago that had a Keith Craft small block 427, single plane intake and I took a Shelbly/Cobra Air Cleaner and a friend cut the base and dropped it so I could run the big element. Worked well. I'm currently running a turkey pan and K&N setup on my FE that I like that has a flat base plate.
CAV GT40
