Like Tree1Likes
  • 1 Post By Cashburn
Old 12-26-2011, 08:04 AM
Cashburn's Avatar
Backdraft Racing Dealer
Default 454 SBF - Anyone tried it yet?
Been looking at some short block offerings in the 454 tall deck variety. 454 seems like a dirty "word" when it comes to Fords though. Anyone built one yet?
IT'S NOT REAL. IT'S UNREAL.
VINTAGE MOTORSPORTS
Old 12-26-2011, 08:17 AM
Hotfingrs's Avatar
Cobra Make, Engine: EM cobra, 450 inch sbc running a best ET of 9.14..so far..ALL MOTOR...approx 800 horse.............ERA with 482 FE..All Aluminum Engine
Send a message via Yahoo to Hotfingrs
I've had one for 3 years now, but it's the SBC variety.....
Jack
XSSIVE .....
Old 12-26-2011, 08:32 AM
Cobra Make, Engine: SPF GT40
How do you get to 454 (bore & stroke)?
Old 12-26-2011, 08:53 AM
Cobra Make, Engine: Everett-Morrison, 434 cid
You could go 4.155 x 4.25 for 460cid
Old 12-26-2011, 08:58 AM
bobcowan's Avatar
I considered it for my Dart block. Two issues came up while I was thinking about it.
First, the bore is maxed out. If something happens, you have no option except to sleeve the bock.
Second, there were no readily available off the shelf pistons. I found some race only pistons - but the compression was way to high, and so was the price.
.boB "Iron Man"
NASA Rocky Mountain TTU #42
www.RacingtheExocet.com
Old 12-26-2011, 09:23 AM
Cashburn's Avatar
JE 4.125" bore pistons and 4.250" stroke 4340 forged Eagle crankshaft...
"This engine produces 643 horsepower at 6100 RPM and 597 ft pounds of torque at 5200 rpm. Torque at 3500 is over 525 ft pounds"
VINTAGE MOTORSPORTS
Old 12-26-2011, 10:18 AM
RodKnock's Avatar
I thought when you stick a 428 FE crank in a 427 FE, you get 454ci. I wouldn't worry about nomenclature.
Old 12-26-2011, 02:37 PM
Sure...what would you like to know?
You can get there with either a 4.100" stroke or a 4.250" stroke.
Pistons for both 4.100" and 4.250" are readily available from Probe, JE, Diamond, Mahle, etc, etc.
They produce a tremendous amount of torque along with a large amount of average horsepower.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
Old 12-26-2011, 02:51 PM
bobcowan's Avatar
A while back I talked with the folks at JE Pistons. You can buy off the shelf pistons with 4.125" bore for only a couple of strokes, and 4.250 was not one of them. On their web site, that still appears to be the case. When I talked with them, they said they could easily make them, but they don't generally stock them. So they had to be special order and custom made = expensive.
Same thing with the Eagle crank. They can do it, but it's a special order. That doesn't seem to affect the price any, though.
I'm not sure what rods you would need, a little shorter than normal, I would think. Eagle doesn't list a package >445 cubes; and that uses a 4.100" crank, and a 4.155 bore.
If you use a Dart block with max bore and stroke, you can get 468 cubes. But the engine is maxed out, the stroke is huge, and the price is even bigger. I thought about it for a while, but then decided not to do it for a variety of reasons - price being one of them.
SBF = Small Block Ford
.boB "Iron Man"
Old 12-26-2011, 03:06 PM
Pistons are available. Cranks are available. All off the shelf.
With increased stroke, rods get longer. You need a 6.250" or 6.300" rod length depending on the counterweights of the crankshaft and the compression height of the piston.
All prices are the same. The cranks are the same price, rods are the same price, pistons are the same price.
The only issue is that with the 4.250" stroke, the pistons start to get pretty short. However, Probe offers some off the shelf pistons that use a 6.250" rod, which helps a little bit.
If you have to have "exactly" 454 cubic inches, then you can do a 4.125" x 4.250". If you can fudge a few cubes either direction, then there a myriad of ways of getting there. People tend to get caught up in the numbers though.
Old 12-26-2011, 03:41 PM
Cobra Make, Engine: Backdraft, SBF 351w (463 CI)
Jay I have 460SBF, and i have been pleased. Parts are not a problem (as Brent mentioned). You will need to Notch the block (Dart Block).
Old 12-26-2011, 04:55 PM
RodKnock's Avatar
My point was not that I didn't know what SBF meant, but that 454's, BBF's in this case, have been around a long time. No need to worry about the number 454 in a Ford, in my opinion.
Old 12-26-2011, 08:38 PM
Cashburn's Avatar
Sounds like fun.
VINTAGE MOTORSPORTS
Old 12-26-2011, 09:34 PM
Rick Parker's Avatar
Why not just play with a used detuned Cup Engine with all the good parts already in it?
Rick
Old 12-27-2011, 01:42 AM
Cobra Make, Engine: jbl
didn't blykins build one not too long ago?
Old 08-05-2014, 05:30 PM
Default I built a 454 Windsor
I build a 454 Windsor with AFR 225 cylinder heads 10.7.1 compression super Victor intake solid roller, Cam kooks 1 7/8 in headers c4 with an art car 5400 converter 3.73 gear with a 112 lope separation camshaft it runs 6.22 on motor with a 150 shot it ran 5.87 in the eight on non-tub 10 1/2 inch Mickey Thompson's et slicks it's a street car!
Old 08-05-2014, 08:25 PM
Cashburn's Avatar
4+5+4=13
4+2+7=13
Lucky number
Markbowers3740 likes this.
VINTAGE MOTORSPORTS
Old 08-06-2014, 09:45 AM
MOTORHEAD's Avatar
Cobra Make, Engine: KIRKHAM 427 S/C, SHELBY 427 ALUM. STROKER
Some years ago we had a sbf 460 from Bill Mitchel? World Products. There was a thread here on it.Initial problems were all EFI related.
My stock bore Shelby block with 428 crank works out to 452 cu in I believe. Close enough ! All the mfr's always round UP !!!
"When Injustice becomes Law,
Rebellion becomes Duty." T. Jefferson
Old 08-06-2014, 02:25 PM
Thor maine's Avatar
454, Come to the Dark Side!!
Old 08-19-2014, 03:40 PM
PANAVIA's Avatar
How about an LSX454R and tip the HP to 750 out of the box.
Hecho En USA !
