December 2025
Old 03-16-2012, 03:28 PM
GBowman's Avatar
Cobra Make, Engine: BDR #1230/B2 445CI SBF
Default HELP!!! Thermostat switch
Switch went bad-fan runs with ign off/on-got a part # from BDR but the cross over part I got was a 92-87 deg C, The switch I took out is a 82-68 Deg C switch. Does anyone know a part # or switch I can use that has the same thread 22/1.5 and degree setting? thx
Gary Bowman
Voorhees NJ/Key Largo Fla/Ventnor NJ
Old 03-16-2012, 03:31 PM
Rick Parker's Avatar
They are available and made by Wahler.
Used on a lot of earlier VW Rabbits, Audi's and 924 Porsches.
Rick
Old 03-16-2012, 04:26 PM
mln385's Avatar
Don't the newer BDR's fans run untill it cools down after you shut them off?
Old 03-16-2012, 09:01 PM
GBowman's Avatar
Having trouble finding a M22 x 1.5 in the correct temp range-what a PIA. I can't see letting the coolant get to 198 deg F before the fan kicks on.
Gary Bowman
Old 03-16-2012, 10:17 PM
Check the numbers stamped on it again. The range seems quite large, generally they are 5-6 degrees C. Here is on that will close at 180 F:
1979-1987 Saab 900 Auxiliary Fan Switch - W0133-1635865 Wahler - Cooling System 79-87 900 Auxiliary Fan Switch - PartsGeek.com
Rick
Old 03-17-2012, 08:55 AM
Cashburn's Avatar
Backdraft Racing Dealer
Beck Arnley 201 1545
IT'S NOT REAL. IT'S UNREAL.
VINTAGE MOTORSPORTS
Old 03-17-2012, 09:43 AM
GBowman's Avatar
Jay that switch closes at 198 deg F-Is that OK with my alum motor?
Gary Bowman
Old 03-17-2012, 09:45 AM
GBowman's Avatar
Jay the one I removed from my car closes at 180 deg F FYI
Gary Bowman
Old 03-17-2012, 10:09 AM
GBowman's Avatar
Jay
As usual-you gave me good info, the Beck Arnley 201 1545 I gave to NAPA originally-they crossed referenced another manufacturer and the part was not the same. So if anyone has the same issue be sure to look at the stamp on the switch before you install it...Thx!
Gary Bowman
