Old 06-05-2012, 03:25 PM
mreid's Avatar
Default Please check this plug
Take a look at this plug and tell me what you think. 427w, Edelbrock performer rpm air gap, Holley 750HP. The engine runs great, but when I look at this plug (all others are the same) with 200 miles on it, it looks a bit lean. I think I need to richen the primary jet, but wanted some other expert input first. I know the pic is a little blurry.
RCR GT40 SOLD to Fast 5
Kirkham #690 289 FIA
Old 06-05-2012, 03:31 PM
bobcowan's Avatar
Unfortunately, in a modern engine it is very difficult - if not impossible - to tune the engine by reading the plugs. If it's covered with soot, it's really rich. If it's oil fouled, it's probable not firing. That sort of thing. Otherwise, you need a wide band sensor to do a really good job of tuning.
If you think it''s a bit rich, I'd leave it there. Better to be a bit (not a bunch) rich than a bit lean.
.boB "Iron Man"
NASA Rocky Mountain TTU #42
www.RacingtheExocet.com
Old 06-05-2012, 03:59 PM
Can you take a picture with the flash on?
Also, if you could snag a picture of the ground strap, we can see if your timing is close....
Old 06-05-2012, 04:07 PM
Thats how mine looked after the first few miles too. Thought I was a bit lean also. After a few more miles, they settled into a light brown color and I'm fine.
However, richer is always better than leaner when in doubt. Unless the ceramic insulator is bleached white, or has tiny blisters on it, then I would drive it a bit more and check again. But go easy on the gas pedal till your fears are eased.
Old 06-05-2012, 05:24 PM
It is fine.
Just get out there and beat it harder!
Old 06-05-2012, 05:26 PM
maybe too much anti seize
and switch to Denso Iridiums
Old 06-05-2012, 05:28 PM
Vinny said your carb needed some tuning too. You should call him
Old 06-05-2012, 05:35 PM
The groundstrap looks about right on. You could put a little more timing in it. Where is it now 32ish? and mouse grey/brown is what you want for color.
Old 06-05-2012, 07:55 PM
Dwight's Avatar
Smile
try this link
it has pictures
sparkplugreading
ethanol gas does not read like the old gas we bought years ago.
Dwight
Old 06-06-2012, 02:54 AM
JB...
The part of the ground strap that shows total timing isn't visible in this picture....at least not on my monitor.
I see a mark in the radius of the strap, but it looks more like a shadow.
I do think his right rear tire is low on pressure though.
Old 06-06-2012, 04:31 AM
Gaz64's Avatar
I agree with a lot of comments from others, but to me, the porcelain colouring up after 200 miles says your rich.
Don't go by porcelain colour too early, you should be looking at the outer shell and the ground strap.
The outer shell for A/F ratio, and the ground strap for timing and heat range.
Get hold of a wideband A/F ratio gauge with data logging capability, hook up the necessaries like rpm, tps, map etc.
You can do all of this even if you run carburettors.
Old 06-06-2012, 06:32 AM
Cobra Make, Engine: jbl
i'd say looks good for a carb'd engine but you may want to read here.
Spark plug reading
Old 06-06-2012, 06:59 AM
lovehamr's Avatar
Stolen Avitar
Yup, that right rear tire is FUBAR..............
Old 06-06-2012, 12:34 PM
mreid's Avatar
Thanks everybody. I know the picture is not the best and I'll try to get a better angle and clarity. What I am concerned about are what appear to be tiny flecks of aluminum on the insulator. In the old days that was a sign of a lean engine, but this one runs really well without the other usual lean symptoms. Could it be too much antisieze as JB suggests? My primary jet is a 68, which feels like it would be too small for this engine. I was thinking a 72 is more inline, but performance tells the story.
Old 06-06-2012, 12:35 PM
Could very well be antiseize....that stuff goes everywhere when it gets hot.
The plug doesn't look like it's been cooking to me...
Old 06-06-2012, 12:52 PM
Hi Mark
That is all it is...anti seize
A little goes a long way.
Your car runs great. I showed Vinny and it is a tad fat.
If you try the NGK or Denso Iridiums it may turn out just about perfect on the tune.
