Old 10-05-2012, 10:11 PM
Dangerous Doug's Avatar
Cobra Make, Engine: ERA 289 FIA #2108
Default Source for 5/8"-11 plugs for AFR-185 heat pump holes?
Okay, I've looked at boltdepot.com, graingers, and fastenal, and even Ford Racing and AFR themselves, and I cannot find a source for brass, stainless steel, or chrome (or any metal, really) threaded plugs for the 5/8"-11 threaded heat pump holes on the front and back of my AFR-185 heads.
Am I missing something here? I suppose I could use bolts, but the elegant solution is chrome or stainless steel countersunk hex (Allen) plugs.
As I'm not in a total hurry as I assemble my 331, I've got time. However, there is a point at which one must admit this effort is ridiculous---hmm, I've already passed that point, now, haven't I?.
Anyhow, sage advice welcome.
Where (Oh, where!) can I obtain these plugs?
DD
Dangerous Doug
"You're kidding, right?"
Old 10-06-2012, 03:27 AM
Cobra Make, Engine: superformance 1022
Doug check A&A Bolt and Fastener in Baltimore. They have an incredible variety. Their phone is 410-687-8831. Best of luck. Tom
Old 10-06-2012, 03:50 AM
Cobra Make, Engine: factory five mkIII roadster 445 fe quick fuel 750 q series,irs
I know edelbrock supplies them when you buy there heads, I would try a automotive machine shop. I would also try mike forte from forte's parts connection I believe he stocks them.
factory five mk III roadster, 445 fe stroker
Old 10-06-2012, 04:55 AM
Cobra Make, Engine: jbl
if you have a bolt you could cut to length then slot for a screwdriver
Old 10-06-2012, 05:37 AM
MacGyver's Avatar
Cobra Make, Engine: B&B 5.0 roller W/carb & T-5 WC
Call Keith Craft. They installed the ones in the 185,s I bought from them. The insert also allows the use of a slightly smaller bolt as they are threaded on the inside as well. Awesome company and service bar none.
"Oversteer is when the passengers are scared. Understeer is when the driver is scared."
Old 10-06-2012, 11:54 AM
Rick Parker's Avatar
Aren't these an OEM Ford part used on the 5.0 heads. I had to get them for use on my World products heads. The heads are then essentially plugged on then both ends the threaded inserts are internally threaded and allow accesory bolts to be used. Otherwise the heat tubes that are part of the OEM emission system use a hollow banjo bolt that screws into them on the firewall end with one of the mentioned plugs at the front of each head, allowing for accessories to be attached at the same time.
Rick
Old 10-06-2012, 03:02 PM
FWB's Avatar
FWB FWB is offline
McMaster-Carr
you call them plugs but a 5/8-11 is a standard machine screw thread, so a set screw will be the only thing out there...the above is a link to some SS ones , pg 3072 about halfway down, 18-8 SS,,,,choice of lengths
Fred B
Old 10-07-2012, 06:43 PM
I had an "aha!" moment when I removed one of the thread reducer inserts from one of the holes---the inserts are capped on the inside end, making them a seal in and of themselves. So, to seal these holes you could just use four inserts, one on each end of both heads.
Looking for something else today down at the hardware store I found a separate section of the set screws and found the 5/8"-11's there.
So, in case someone else stumbles across this thread looking for answers...
DD
Dangerous Doug
Old 01-28-2013, 08:57 PM
PANAVIA's Avatar
The ford part works great - Or cup set screws like ; McMaster-Carr
