Like Tree1Likes
LinkBack Thread Tools Rating: Thread Rating: 2 votes, 5.00 average. Display Modes
Old 02-28-2013, 08:46 PM
Originally Posted by AL427SBF View Post
That's a little different, looks like your HP and Torque intersect at ~5600 RPM.
They intersect at ~5600, but the values are not equal at that point. At 5250 the values are equal.
Old 02-28-2013, 09:01 PM
yep, I just noticed the HP & Torque scales are different on each side of the graph. Nor does your RPM scale follow normal convention (n x 1000), that is one funky dyno plot, but a dyno plot it is
Old 02-28-2013, 09:12 PM
Originally Posted by tcrist View Post
Well I was going to post them. Had them my photos and tried to post them but they were so blurry they were unreadable.
Screw it.
well, when you look at her curves what do you see ...
42-24-32
36-24-36
34-24-38
Old 02-28-2013, 11:03 PM
Ok, Cropped them and that did help.
Terry
Old 03-01-2013, 08:31 AM
I like your torque curve, pretty flat/smooth in the 3K-4.7K range, makes the mountain twisties manageable and fun. No Dolly Parton there, but I see a little Jennifer Lopez
Old 03-01-2013, 09:21 AM
undy's Avatar
...found an old chassis dyno for the Cobra.
Too many toys?? never!
Old 03-01-2013, 10:18 AM
That's a pretty interesting comparison between the two dyno runs. Peak HP and Torque virtually the same and from 4000 to 6200 the curves lay on top of each other. Below 4K it's a different matter. I'm assuming you did a carb tweak or something to improve low end torque at the expense of some low end HP? Hard to tell with the color resolution of the actual graphs (order of the runs). If it were me, the Torque ramp starting at 2200 is where I would have left things - the tune I would be looking for.
Old 03-01-2013, 10:21 AM
Cobra Make, Engine: FFR
Old 03-01-2013, 10:49 AM
Nothing wrong with Jennifer Lopez. Had a few Dolly Parton's before. Really tempermental. Especially the MENTAL part.
Terry
Old 03-01-2013, 12:54 PM
twin turbo you have a real beast, incredible power and the torque looks down right scary. I'm sure 9's easy with a decent track, trap speed killer too.
tcrist, I would rather have J.Lo as my main squeeze
Old 03-01-2013, 02:01 PM
undy's Avatar
Carb tweaks and linkage adjustments...
I running twin Quick Fuel 750s on a tunnel wedge. I also think the go-fast pedal got mashed at different RPMs and the vacuum secondaries took a moment to open all the way. The larger CFM carbs causes the secondaries to be a bit more sluggish than, say twin 600s.
Old 03-01-2013, 02:13 PM
Great example of some quick carb tweaks and how that can move the power around, those runs were about 10 minutes apart.
  #33 (permalink)
Old 03-01-2013, 04:24 PM
scootter's Avatar
Here's mine after I rebuilt the Ford Crate 514 after 13k miles on the chassis dyno.
  #34 (permalink)
Old 03-01-2013, 05:20 PM
RW numbers so pretty nice scooter, building power all the way up.
What do the 3 runs signify?
Run 1: Before?
Run 2: After?
Run 3: The Triangle Plot?
  #35 (permalink)
Old 03-01-2013, 09:18 PM
scootter's Avatar
The triangle plot is supposed to be typical. I was surprised it made that much power as I changed the cam from roller mechanical, to flat hydraulic. The original cam was like 605/615 and if I remember right the new one is 590/605. Since those runs, I changed the carb from the HP4150 1050 CFM to the BG Demon 850. Can't tell much at the bottom, but sure can at top end.
Scott
  #36 (permalink)
Old 03-02-2013, 09:54 AM
Definitely some sweet power there, with 1050 CFM I would think you were over-carbed, the BG Demon 850 makes more sense to me on your 514. In talking to some builders, over carbing these stroked motors seems to be a common thing. Throttle response doesn't seem to get due consideration along with the rest of it, many things to consider when selecting your carb.
  #37 (permalink)
Old 03-02-2013, 12:21 PM
undy's Avatar
Just curious...
How many are posting standard numbers versus SAE?
  #38 (permalink)
Old 03-02-2013, 01:10 PM
bobcowan's Avatar
This one was done a few years ago. The engine has gone through a number of changes since then, which have added power. The last dyno tune showed 510 peak hp. But I just made some big changes that probably decreased power a bit; but it hasn't been to the dyno yet. In any case I like this one because of the comparison.
The initial test was done with "Tea Strainer" filters on the stacks. Then we popped the air cleaners off and did another run right away. No other changes, just removed the tea strainers. The difference is nearly 100HP! Looking at the AFR curve, I suspect that you could gain some of that power back by leaning out the mixture a bit. But I doubt you'd get 100hp. I doubt you'd even get 50hp. Those filters are really restrictive.
.boB "Iron Man"
NASA Rocky Mountain TTU #42
www.RacingtheExocet.com
  #39 (permalink)
Old 03-02-2013, 05:51 PM
Very interesting Bob, the guys running stacks thinking and I bet the same may apply to any intake filtering. Wonder what the solution is, I have to believe those filters are already "hi-flow", don't think running your stacks open is the solution either.
  #40 (permalink)
Old 03-02-2013, 09:32 PM
bobcowan's Avatar
On the track I leave the stacks open. On the street I use these 4 oval K&N filters. I'm sure they cost me some power, but there's plenty to go around.
Pierce Manifolds sells a SS mesh filter that they claim has "virtually no air flow resistance." One of these days, I'll spend the $200 for them, I like the look.
.boB "Iron Man"
