Like Tree3Likes
Old 06-29-2013, 09:47 PM
Rick Parker's Avatar
Default New engine on the horizon
Does anybody know the comparative weights of a Boss 302 Rod 5.155 c/c and that of a 5.400 Scat H beam for standard Crank Pin diameter and .912 Piston Pins?
Old 06-30-2013, 01:16 AM
Dimis's Avatar
That's well and truly beyond my knowledge...
But I'm interested to hear more about your new engine.
Will you still be running webers?
Your knowledge and posts about them has me learning plenty.
Old 06-30-2013, 04:41 AM
Jac Mac's Avatar
Rick , according to my Boss 302 Info...
Standard Boss 302 5.155" rods weight is :581/593 grams ( Same as 289 HP )
For balancing purposes the Big end weight is 421 grams ( per rod ), Small end is 166grams.
On the basis of those weights the total bobweight per journal for a stock Boss 302 being blueprinted with stock pistons etc was 1838.8 grams.( Thats for cross drilled crank- use 1827.8 grams for non- cross drilled to account for the oil weight factor )
Have a couple of Scat 5.4 rods here somewhere I could weigh, but they are all 927 pin variants.
Think we have discussed this motor already, are you trying or hopeing to work with your existing crank, in which case you should be able to weigh the old reciprocating components in order to figure what the original bobweight would have been....as long as your staying with the original damper/flywheel etc..
Jac Mac
Last edited by Jac Mac; 06-30-2013 at 12:53 PM.. Reason: additional bob weight info.
Old 06-30-2013, 05:50 AM
Snakebit's Avatar
I did a 68 302 block stroked to 331 using a Scat forged crank with a 3.25 stroke, Crower 5.315 sportsman rods and JE pistons 188704 with a CH of 1.250, keeping the wrist pin out of the oil ring grove. Billet steel main caps 2,3,4. Canton main stud girdle, AFR 185 outlaw heads 58cc for a cr of 10.3, Miling blueprinted HV pump, Compcams 282S solid cam, and a Crower billet timing chain set. Running Webers with 40mm chokes.
prp289 likes this.
Snakebit
Old 06-30-2013, 05:50 PM
Rick, give me a call.....you're worrying way too much about this connecting rod stuff.
Use the longer rod, keep the piston short. Don't worry about wrist pins intersecting the oil rings. It's a non-issue and has been perpetuated on all the forums for no reason.
Old 06-30-2013, 10:19 PM
I agree with Brent go with the longer rods. They are better and will keep the piston higher in the cylinder when at the bottom. I find this a bigger concern than the ring deal which is no problem. The shorter rods pulls the piston out the cylinder at the bottom for more piston rock.
Good luck, Keith
Keith C
Old 07-01-2013, 03:53 AM
Snakebit's Avatar
I respect your opinions, but placing the wrist pin in the oil ring groove just isn't natural. As far as using a 5.315 rod vs a 5.4 rod, you are talking .085" difference. Just one more thing to help me sleep better at night knowing that the engine will not turn into an oil burner.
Snakebit
Old 07-01-2013, 04:50 AM
It wouldn't.
But peace of mind is a wonderful thing.
Think about how many fox mustangs there are across the us running 347's with 1.090" pistons. They are not rolling smoke shows. This is extremely common and even the 4.300" stroke bbf pistons come this way.
Once upon a time, I think someone jacked up the ring install or got the hone job wrong on a build and contributed it to the piston design. As you know, there are lots of bench racers on the Internet, so the idea stuck. :-)
Old 07-02-2013, 03:36 AM
While I generally agree on it not being a huge deal, I will only pierce the oil ring groove on a race or performance package if it's the only way to satisfy other limitations - such as pulling the pin out of the bore or banging the counterweights on the pin boss. Or a checkbook limitation.
But if there is any other way I will avoid it. A narrower ring pack (.043-.043-3.0mm) coupled with reduced crevice volume can get you some good usable real estate up there (over .100") for modest cost and you end up with a nicer package as a result.
Consider the development budgets in the OE world and list the number of engines built with pin/ring groove intercepts.
That 5.315 rod ain't a bad deal either - it just never caught on with the bigger is better crowd. I do like the short CD for keeping the roll couple of the piston small - keep the ring pack squared to the bore and stable - don't need a long heavy piston since the working part of the skirt is all below the pin.
Survival Motorsports
"I can do that....."
2008 - 429 cid FE HR - 675HP
2007 - 429 cid FE MR - 659HP
2006 - 434 cid FE MR - 678HP
2005 - 505 cid FE MR - 752HP
Old 07-02-2013, 03:53 AM
I don't know of many Cobra/Galaxie/Mustang engines trying to hit the 200k mark though...
OEM and what we deal with is certainly a good distance from each other.
With that being said, we may all have our theories/preferences, but again, I've never really seen any oil consumption or wear issues because of the oil ring placement. Most of my engines fall into the street/strip category, with some a little more strip than others. I do dabble with the LS crowd, BBF, FE, and SBF stuff, and it's not uncommon to see the oil rail support in the piston box.
While each point has its own merit, I do believe that the wrist pin/oil ring fiasco has really had its own evolution, carried on by most of the guys on The Corral and www.yellowbullet.com.
Old 07-01-2013, 07:56 AM
This will be a 3" stroke engine, essentially an overbored 302. I have a real nice professionally prepped Boss 302 Steel crank (thank you ERAChas) that will be internally balanced. I will use a 5.4 rod and am leaning towards the Scat H Beam with a .912 pin. I will probably use an ATI balancer. I want the reciprocating assy to be as light as feasibly possible, from my perspective this is an important issue, hence my concern.
Old 07-01-2013, 08:56 AM
For something around your horsepower level, I would use a light I-beam rod. Crower makes a nice Sportsman rod that isn't too much more than the Scat piece. Light piston, light rod = light bobweight.
car4jim likes this.
Old 07-02-2013, 11:45 AM
Cobra Make, Engine: jbl
With only a 3" stroke and looking to go 'long' rod light piston with internal balance, aluminum rod comes to mind.
Old 07-02-2013, 05:45 AM
Great to have three pros weigh in with opinions. We need more of this on CC.
Makes for more educated engine customers for the builders too.
Chas.
Old 07-02-2013, 10:52 AM
If you don't believe in OE development you can pop on over the "evilbay" and take a look at NASCAR take-outs. They have vacuum & dry sumps and still seem to leave the pin out of the groove when feasible.
The punched groove is a drag race specific deal that has migrated into the street world in order to accommodate the popular stroker crank & rod combinations. That said, there are eight hundred gazillion cars running around that way, so it obviously can work fine - just not my preference.
Old 07-07-2013, 12:02 PM
Well, I don't think it's for that specific reason. Cup applications use a 9.200" deck with a 3.500" stroke, so the piston isn't going to be uber short anyway. Compression heights are high 1.200's to 1.300's. Couple that with the fact that wrist pin diameters get really small (some are down to around 3/4"), the pin is easily kept away from the ring pack.
Old 07-07-2013, 09:42 PM
DAVID GAGNARD's Avatar
Actually all of the Roush/Yates engines used in cup cars use a 3.25 stroke crank......
DAVID GAGNARD
Old 07-08-2013, 01:49 AM
Jac Mac's Avatar
Smile
I thought the idea was to start out at ~4" bore & 3.5" stroke then each time the engines were rebuilt to increase bore & reduce stroke to maintain the 355 cu in, hence virtually everything we see for sale is on its 'last' life so to speak, or have they since found the 3.25" stroke & ~4.185" bore is the better combo and now just going straight to those dimensions... the bigger bore does increase the valve/bore distance.
Jac Mac
Old 07-08-2013, 01:58 AM
David's right. They generally favor the shorter stroke, but I've seen the smaller bore combination on a few engines, especially if we're looking at "Ebay take-off's."
Old 07-08-2013, 05:56 AM
In NASCAR the cubic inch limit is 358,back in the day they would start out with a 350 chevy or 351 ford and this would allow for a few rebuilds/borings on stock blocks..........that has long since gone the way of the dinosaur,nothing is "stock" in the cars or engines and has been that way for a long time......
They want fast revving short stroke engines now-a-days hence 3.25 inch stroke,depending on the track, they are turning these engines 9500 +rpms and they have to use a solid lifter, non-roller camshaft....These engines only have to last one race,so saving a few dollars is not in the equation.....
Yates has experimented with stroke combos in the 3.10 inch range........
DAVID GAGNARD
