Old 02-07-2014, 07:31 PM
Dwight's Avatar
Smile 302 stroker block jig
I'm looking for a Ford Stroker Block Clearance Tool / Jig for a 347. Hawk Racing had them a few years back but their out of business.
Does anyone know where I can buy or borrow or rent one?
Thanks Dwight
Old 02-07-2014, 10:58 PM
I have a Nowak small block clearancing tool if that is what you are looking for. If you're interested, let me know in a PM so I can send it off.
Old 02-08-2014, 03:47 AM
Check it first. Depending on the rods you use, you may not have to touch anything. I grind about 50% of the blocks I use.
Lay the crank in the block, then just use a rod cap with bearing and bolts and roll it around. You'll see if you have to grind, and you'll see where you have to grind. No fixture needed.
Old 02-08-2014, 07:23 AM
DAVID GAGNARD's Avatar
That's all I do.......last block/build was on a 1994, 302 block and it needed very minor grinding......
DAVID GAGNARD
Old 02-08-2014, 11:07 AM
Jac Mac's Avatar
When laying the crank in the block leave the center main thrust bearings out also, this lets you 'float' the crank back and forth a little while checking clearance, some crank counterweights have clearance issues as well particularly around pump mount flange.
Jac Mac
Old 02-08-2014, 04:04 PM
Dwight's Avatar
Thanks for the replys
Dwight
Old 02-18-2014, 10:19 AM
Z-linkCobra's Avatar
Bolt it together...it will clearence itself...lol. Just kidding.
Old 03-09-2014, 07:44 AM
Dwight's Avatar
Smile
thanks everyone. I found one and bought it.
Dwight
