10Likes
05-06-2014, 02:44 PM
Knowledgeable Builders Debunk Wives Tales
Let's hear from experienced builders of motors and cars, please share some common misconceptions purveyed across this "world's largest non-biased Cobra site!" ... should be interesting
05-06-2014, 03:52 PM
ok i'll start,
" Wives tales don't necessarily come from wives"
Fred B
05-06-2014, 03:57 PM
Backdraft Racing Dealer
I think the pool is a little full right now, and too yellow.
05-06-2014, 04:51 PM
KY
Oh, where do I start...
Jay, should we drink more water before we pee in it?
05-06-2014, 04:54 PM
In what respect are you speaking of misconceptions? Can you rebuild two cars from the ground up in 60 days like the gas monkey guys...highly unlikely. If you did the sorting out time is going to be 3 times as long at least. Can you call up and order every part you need to build a cobra from Factory Five and get it done in sixty days...most likely. Hell all the car manufacturers build them in a matter of hours.
In most cases it takes a few years to build any car. Family time, work and just plain out of money and I don't feel like fkn with tonight take priority. I have done every ounce of work on my cobra. From laying fiberglass to fabricating my own rear suspension and belt drive distributor. Its been six years of total agony and total bliss all wrapped into one.
Don't know if that answers yours or your wifes question....but there you go....lol.
05-06-2014, 04:57 PM
and...............im not done....lol. Still not in paint and I cant get a damn title for it.
Just thought I would throw that out there...lol.
05-06-2014, 05:14 PM
"I built it within my budget"
Just another wives tale
05-06-2014, 05:19 PM
Originally Posted by AL427SBF
Let's hear from experienced builders of motors and cars...
Darn it. I don't meet the prerequistes. Will there also be a thread for experienced check writers and credit card users?
05-06-2014, 06:25 PM
Cobra Make, Engine: Johnsonville, 8-pack $4.27
Wives tales
You can keep your doctor if you want. Period.
mm
Smoke the meat, only the meat and nothing but the meat... so help me Weber
05-06-2014, 07:27 PM
things like ...
- using a cold air intake requires a tune-up or computer adjustment
- slowing down the flow of antifreeze through the radiator for heat dissipation is better for engine cooling
- if 91 octane runs fine in your motor, a bump to 95 will make it run even better
surely the engine and car builders have learned something along the way that made them say wtf? stuff not expected and "learned" to pass along to the weekend garage mechanic
how about selecting the proper carburetor size to maximize engine performance between throttle response and peak power, oh yeah that's a good one!
05-06-2014, 08:24 PM
Cobra Make, Engine: Lone Star Classics / Roush 427 SR
Power steering and power brakes are not needed in a Cobra.
That should gut it started
Roush #1
Lone Star Classics
Roush Edition #01
Roush 427 SR #444
05-06-2014, 11:57 PM
SI
'It will bolt straight in'....compliments of one ex Boss, everytime he said it meant trouble ahead ..
Jac Mac
05-07-2014, 09:41 AM
OH
Cobra Make, Engine: RCR SLC, Graziano 6-spd, LS3
Here's a couple
1) You should never use a high volume oil pump in a SBF
and
2) It's perfectly fine to use a high volume oil pump in a SBF
05-07-2014, 11:34 AM
KY
Well, the first one is a myth, the second one is dead on.
I've put HV pumps in everything I've built, both SBF, FE, and BBF for years.
"My brakes are perfect because I can lock up the tires!"
This is one that always gets me.
Alba gu brąth
05-07-2014, 11:52 AM
You need to use 20W50 racing oil.
05-07-2014, 01:25 PM
For crate motor builds of same displacement, compression ratio, quality of internal components and tuning - fords make more power than chevys.
05-07-2014, 01:31 PM
to be correct i would change that to more HP per pound
Fred B
05-07-2014, 01:46 PM
Pound for pound, crate motor builds of same displacement, compression ratio, quality of internal components and tuning - fords make more power than chevys.
05-07-2014, 03:56 PM
IN
Cobra Make, Engine: ERA 838
Dollar for dollar, crate motor builds of same displacement, compression ratio, quality of internal components and tuning - Chevys make more power than Fords.
Now I will get the popcorn and kick up my feet.
