06-19-2014, 01:23 PM
Guess The Power Of This Crate Motor
Guess the BHP @ RPM and Torque @ RPM for this crate motor ...
Crate Motor Specs- Torque Plate Honed
- Durabond Performance cam bearings
- Eagle 4340 Steel crankshaft 4.00" stroke
- Callies 4340 Steel H-beam rods 6.300" long
- Clevite Hardened Rod & Main Bearings
- Racetech Forged Pistons with Total Seal Rings
- Compression Ratio: 13.5:1
- Rods (big & small ends) and Pistons machined to same weight
- Rotating assembly balanced to .02 oz/inch or within 2 grams
- Brodix STS Track 1 CNC Ported cylinder heads
- 68cc combustion chambers
- Comp Cams 2.100" & 1.600" SS valves
- Titanium retainers & 10° Locks
- Roller Valve Springs
- 225cc Intake Runners
- ARP Studs and Fasteners
- Comp Cams Mechanical Solid Roller Custom Grind Race Camshaft
- Crower Sever Duty HIPPO Solid Roller Lifters
- Jesel Pro Series Shaft Mounted Roller Rockers
- Jesel Belt Drive Timing Setup
- Comp Magnum Pushrods
- Edelbrock Super Victor Intake w/4500 flange
- Holley 1050 Dominator Carburetor
Fill in the blanks ...
_____ BHP @ _____ RPM
_____ ft/lbs @ _____ RPM
_
06-19-2014, 02:19 PM
What's the bore...?
06-19-2014, 02:23 PM
[b]Assuming its around 4.00". I would say ....675 hp @ 7500rpm and about 640 lbs of torque @ 5400
06-19-2014, 02:34 PM
13.5:1 compression, long stroke, big heads, solid roller cam, Dominator carb...well north of 750HP and probably the torque to match.
06-19-2014, 02:44 PM
Whats the bore? Hope not too big with only a 2.100 intake valve...
E. Wood
ItBites
06-19-2014, 02:47 PM
IL
It would be a waste to build it on a 4" bore block... 4.125 or 4.155 bore.
750hp @ 7400
595ft/lbs @ 6000
06-19-2014, 02:52 PM
KY
Too many variables.
What's the bore? What's the cam specs? What do the heads flow? Has intake been prepped? Whose dyno?
Your question can't be answered as is.
06-19-2014, 03:05 PM
KY
Btw, that ad is pretty bogus.
I wouldn't use comp cams magnum pushrods on a race motor.
Comp cams valves? Lol
06-19-2014, 03:06 PM
Originally Posted by CHANMADD
What's the bore...?
CID is 427
_
06-19-2014, 03:12 PM
KS
Cobra Make, Engine: jbl
North of 600, maybe close to 7. Don't know how they get 750hp out of those heads, suspect afr225 or similar.
06-19-2014, 03:16 PM
IL
Originally Posted by AL427SBF
Nope, I was guessing... honest.
I'd still build with a 4.125+ bore...
06-19-2014, 03:19 PM
MI
Cobra Make, Engine: StreetBeasts, 331 Stroker
So what octane is this set up for?
06-19-2014, 04:03 PM
KS
Either $10 a gallon or methanol
