-   -   427R won't start (http://www.clubcobra.com/forums/small-block-talk/130669-427r-wont-start.html)
Marotte 08-19-2014 02:31 PM
427R won't start
I haven't been using my Superformance w/ Roush 427R since a while recently, and can't have it to start.
Battery is fully charged, air filter is clean. It's cranking. I can even hear the engine puffing a couple of times, but then it smells flooded.
When it's running, it's running perfectly. True bliss :) But that was a few week ago...
Any idea what else should I check?
olddog 08-19-2014 03:12 PM
Do you have spark?
Assuming you have spark: Procedure to start flooded engine. Hold accelerator pedal to the floor. Press it down once. Do not release and press it back down, because each time it pumps more fuel in. Just hold it down, even if you stop cranking for a while. When the engine fires up be ready to back off the throttle, so you do not over-rev the engine. That (too many rpm) can destroy the engine. Letting off the throttle to quickly, before engine clears may let it die. I typically shoot for 2000 rpm, until the engine smooths out. No need to rev high.
PANAVIA 08-19-2014 03:34 PM
agreed - engines are pretty simple - and MSDs can go kaput. -- check for spark, fuel.
mln385 08-19-2014 04:02 PM
Basics of engine are (Fuel- air -spark) do you have all three?
twobjshelbys 08-19-2014 04:23 PM
My MSD went out. At first I thought it was the coil but I swapped it and it was still no spark (note, you can't use a traditional coil short with the MSD - follow their instructions to test for spark.)
1795 08-19-2014 05:25 PM
I had a similar problem and my MSD had gone bad and needed to be replaced. I agree with the prior posts, verify that you have spark, take off the air cleaner and then pull on the throttle and look for gas squirting out, look for obstructions such as spider webs, etc. ( I would also suggest looking at the wires from the ignition module to the coil and distributor to make sure that they have not been chewed), pull the distributor cap and see what it looks like. Check all electrical connections to make sure that they are tight, check the ground for the MSD.
SwiftDB4 08-20-2014 09:08 AM
How old is the gas? If several months old it can be hard to start.
Marotte 08-20-2014 09:19 AM
Gas is new.
Pardon the really stupid question, but... what's the best method to check for spark on the 427R?
madmaxx 08-20-2014 11:03 AM
pull the coil wire of the dist cap and hold next to a bolt and crank the engine. you should see a huge spark or take a plug out and hook it up to the spark plug wire hold plug close to cylinder head bolt and you should see a spark
Another item to check is the MSD dist cap. 99% of the time when installed the rotor tab is not bent up hard enought to touch the carbon button in the cap, over time the jumping spark erodes the botton flat and the cap needs replaced. Bend the tab up so it touches the button and the cap will last forever.
DAVID GAGNARD 08-20-2014 11:05 AM
Originally Posted by Marotte (Post 1315592)
Gas is new.
Not a stupid question at all, simple answer is take off one spark plug wire,one of the front one's is the easiest to get to,then have a friend or your wife stick their little finger in the spark plug boot while you crank the engine,if your engine is firing, you WILL know immediately......:):)
David
twobjshelbys 08-20-2014 11:38 AM
MSD "test for spark" instruction:
MSD Ignition
twobjshelbys 08-20-2014 11:42 AM
duplicate
jhv48 08-20-2014 03:42 PM
[quote=DAVID GAGNARD;1315597]Not a stupid question at all, simple answer is take off one spark plug wire,one of the front one's is the easiest to get to,then have a friend or your wife stick their little finger in the spark plug boot while you crank the engine,if your engine is firing, you WILL know immediately......:):)
David[/
It's easier this way: have your wife or a close friend sit in the drivers seat. Pull the plug wire off of any spark plug, wet your finger and stick it into the plug connector. Now have your wife/friend try to start the car.
If you wake up lying on the garage floor in a puddle of your own piss and have a large bump on your head, you've got spark.
Marotte 08-22-2014 09:35 AM
Thanks for the suggestion, will try all that this week-end.
jhv48 08-23-2014 06:52 AM
You know a couple of us were just kidding, right?
Seagull81 08-23-2014 07:25 AM
There is a pen looking device you can get at the parts store that you lay the tip against the plug wire and it lights if there is spark. Pretty cheap. I keep it in the the car for troubleshooting on the road.
DAVID GAGNARD 08-23-2014 09:07 AM
I wasn't...........:LOL::LOL:
David
Marotte 08-25-2014 04:53 PM
The "stick their little finger in the spark plug boot [...] if your engine is firing, you WILL know immediately" should work. I'm just wondering which "friend" I should invite!
