Old 12-06-2014, 05:22 PM
sharding's Avatar
Cobra Make, Engine: CRII Sebring, Ford 302
Default 302 coolant leak
Been fighting coolant loss this year, finally did a pressure test. Fixed a couple of loose hose clamps, brought the pressure up to 18 psi. Pressure drops about 1 psi every 30 minutes or so.
While under pressure (engine cold), I am leaking from the back of the block. Coolant starts at the top of the oil pan, and drips down to the front of the bell housing. No evidence (that I can see) at the top of the engine - intake, heads, hoses, etc are all dry. Once the pressure on the system is released, the dripping stops.
I have not noticed coolant in the oil, or oil in the coolant. Had the coolant checked for exhaust gas last year - none. No white cloud while driving, but it does spit some water while warming up (clear, doesn't smell like coolant).
Hoping it's not a cracked block! Anyone experience this?
Steve
Old 12-07-2014, 03:30 PM
sharding's Avatar
OK, took another look today. Let it sit under pressure, got a better flashlight, and watched. Found a nearly invisible coolant trickle running along the top of the oil pan gasket to the back. Looks like the timing chain cover gasket has a small leak.
