November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 02-05-2015, 05:28 PM
Default Just found this 260 is it a early run
Here are the block numbers found above the bellhousing right below the back gasket on the intake anyone know the DNA if it's a early run 260 block...many thanks
Numbers...020E - 6015J
Old 02-05-2015, 06:56 PM
It's a C in front of the 2 ...C20E - 6015J
Old 02-05-2015, 10:08 PM
Update the 0 is a C ....C20E - 6015J
Old 02-06-2015, 04:04 AM
Ron61's Avatar
Post
I am not 100% positive about this, but I believe from what my book shows that is a 1962 block.
Ron 61
Ronnie Widener
View my Miscellaneous Gallery
Old 02-06-2015, 06:25 AM
mrmustang's Avatar
Gold Star Contributor
And the date code on the block?
That will tell the real tale.
Bill S.
Old 02-06-2015, 05:13 PM
legenmetals's Avatar
Cobra Make, Engine: contemporary(2) one with 427 sohc and one with 427 center oiler
The C2OE-6015-J denotes a 260 c.i.
The C2OE-6015-G denotes a 221 c.i.
Early engines had assembly date code stamped in two locations. The first place was on the front of the block just beneath the distributor. Another location was about 3" away, along the side of the block near the cylinder head. from Bob Mannel " Mustang and Ford small Block V8 1962-1969. Volumes 1&2. Reply with the numbers that you find and I will help you decipher them.
Old 02-07-2015, 04:46 PM
Okay thanks for info on where the stamped dates are Metals you fellas know the DNA that's why I came to this site many thanks indeed. This is the only raised numbers I could find they were behind the dizzy stamped on the intake if I still need to find the correct one let me know everything is very clean and only numbers I could find... here they are....2C16 or how many digits am I looking for if those are not the correct ones. Dang fellas many thanks again
-Cheers from the PNW
Old 02-07-2015, 04:57 PM
Bill S.
Thanks Bill just found the raised numbers on the block 2C16. 1962 March 16th is the block some of the first runs only has 36,600...Many Thanks
Old 02-07-2015, 11:43 PM
frdfver's Avatar
Cobra Make, Engine: N.A.F., 351 cleveland, 9" ford
Barnfind,
Do you have plans for this 260..Maybe a early Cobra build.
Paul...
Old 02-08-2015, 09:49 PM
No plans the engine is in my 62 Mercury that I found in a barn 6 months ago all original thought it had one of the first run 260 in it so I to start digging. Nice to share my block info so other builders can scope where some of these gems still are. Be nice to see what the early J blocks go for..Great site
