Like Tree4Likes
  • 1 Post By 2bars
  • 2 Post By legenmetals
  • 1 Post By avanti-176
Old 12-03-2017, 07:45 AM
Default engine block painting
Once I get my block back from the machine shop I want to go ahead an paint the block black. Not too concerned about having a paint job that I can shave in front of. I was looking at the eastwood paint and using a foam brush. Anyone had any luck this way and if so any pics?
Old 12-03-2017, 09:07 AM
I use Duplicolor or VHT engine enamel. It's spray-on, in a rattle can. A satin black seems to give the most desired finish for 60's Ford black.
Make sure you wash that block really good, even after it's washed at the machine shop.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
Old 12-03-2017, 09:59 AM
eschaider's Avatar
Neutral
+1^. You are the final inspector when you are the builder. You will be amazed at what is lurking in places you would never suspect — and thought were good to go.
Ed
Old 12-04-2017, 02:34 PM
Cobra Make, Engine: Superformance, 427 FE
I have used the eastwood engine paint and I do think it is one of the best. far exceeds anything that comes out of a spray can. I used Chevy orange (on a Chevy) and it still looks good
1985 CCX likes this.
If enough people disagree with me, I know I am doing it right
Old 12-04-2017, 06:09 PM
legenmetals's Avatar
Cobra Make, Engine: contemporary(2) one with 427 sohc and one with 427 center oiler
Default Block Paint
This is what I use on a block from the machine shop. I washed the block with soap and hot water before painting.
1985 CCX and joyridin' like this.
Old 12-12-2017, 03:42 PM
joyridin''s Avatar
We have an Eastwood store a few miles away. Their paint is expensive, but it is the best I have ever used.
I took their Alumablast and painted my old master cylinders. Even brake fluid won't eat the stuff.
Old 12-12-2017, 07:32 PM
jetblue69's Avatar
Cobra Make, Engine: ERA #816, 427 Side Oiler
Default Por-15
I used Por-15's engine kit on a Rat motor once...The motor took a dump and when I rebuilt it the machine shop tanked it 3 times and the paint still didn't come off. I was rather impressed but I still resort to the rattle can of Dupli-Color engine enamel these days. Cure it with a heat gun and it works just fine.
Old 12-13-2017, 05:47 AM
avanti-176's Avatar
Cobra Make, Engine: Contemporary classics 3041,sbc 350(have no fear ford guys for there is a FE 428 in the garage waiting to be rebuilt & installed) but for now she is a driver while other projects take precidence.
I had the same experience. Guys at the machine shop were stunned at how hard the Por-15 paint was to get off.
THOUGHT FOR THE DAY: There is more money being spent on breast implants and Viagra than on Alzheimer's research. This means that by 2030, there should be a large elderly population with perky boobs and huge erections and absolutely no recollection of what to do with them.
Old 12-13-2017, 08:05 PM
Did Yall spray on the por or foam brush?
Old 12-14-2017, 05:41 AM
avanti-176's Avatar
I put it on with a paint brush, seemed a little easier to get into the nooks and crannies. There was not a single brush mark when finished, the stuff just smoothed itself right out and looked like I sprayed it.
If you do use a paint brush, make sure it is a cheap one. Definitely a one-way
ticket for the brush.
tailpilot likes this.
