Like Tree9Likes
Old 02-14-2019, 08:47 AM
ALF's Avatar
ALF ALF is offline
Default HELP! I need a rectifier (Diode) plate for my alternator
I need to replace the faulty rectifier plate on my C3SF-10300A alternator.
Can any one provide me an address I can find such one?
MANY THANKS
Driving with your Cobra is fun,
Racing with your Cobra is amazing,
Driving hill-climbing races with your Cobra is.... HAVEN!!
Old 02-14-2019, 11:38 AM
Cobra Make, Engine: ERA 3012
I believe the part numbers you are looking for are c4az-10373-a and c4az-10377-a. I bought mine from ebay. Looks like there are some available there now actually.
Old 02-14-2019, 11:39 AM
Tom Wells's Avatar
Alf,
Here's another possibility: Alternators
Tom
Old 02-14-2019, 11:57 AM
Dan Case's Avatar
Original Shelby Owner
If you know which diode(s) are bad, they can be replaced. If there is an old starter alternator repair shop around you they will probably have diodes. I replaced a single diode in our black car's alternator decades ago.
CompClassics likes this.
Dan Case
Old 02-14-2019, 11:59 AM
Senile Club Cobra Member
Originally Posted by Tom Wells View Post
Alf,
Tom
Those are "2G" units and different from what Alf has.
rick@autoventureusa.net
Old 02-14-2019, 01:58 PM
ALF's Avatar
ALF ALF is offline
N to + are defect
I was today on a shop specialized on old cars electric.
He mentioned to me they can not be replaced one by one...
If yes it would be great. If not I‘ll search for the complet part.
The only option I‘ve at the moment is a new alternator for many $ as there are no spare parts abailable.
If the numbers on the post from Andrew are correct I‘ll search for them.
Old 02-14-2019, 02:29 PM
Originally Posted by ALF View Post
N to + are defect
Let me look in the bin, I may have a good used plate.
Old 02-14-2019, 02:40 PM
ALF's Avatar
ALF ALF is offline
Many thanks
I cross my fingers!!
Old 02-14-2019, 02:57 PM
Dan Case's Avatar
The plates listed Feb 2, 1964 printing had C3SZ prefixes for + and - plates. The Aug 1, 1966 printing shows the C4AZ prefix numbers as service parts.
The C4AZ models are not all that uncommon on ebay®.
Diodes are not hard to replace but the 1964 Ford manuals is great to show and tell how.
ALF and CompClassics like this.
Dan Case
Old 02-14-2019, 06:57 PM
LMH's Avatar
LMH LMH is offline
A little advise, be very careful with those brushes when you reassemble the alternator. They break easily if you don't retract them during assembly. Ask me how I know this!
Alba gu brŕth
Old 02-14-2019, 07:09 PM
cycleguy55's Avatar
Ford didn't start using 2G alternators until 1982. Those at the link appear to be variants of 1G alternators.
Brian
Old 02-14-2019, 10:30 PM
ALF's Avatar
ALF ALF is offline
My Manual is somewhere between Los Angeles and Switzerland
For me the challenge will be to get the correct parts from the states as here in Switzerland they know about Porsche and VW and if you’re lucky Ford Mustangs.
Old 02-15-2019, 01:26 AM
You are correct, I mis-typed. However the new AMK units are really a "1G MK II" alternator as most parts will not interchange with the 63/64 round case, plug in type unit.
I do have new brushes for the early 1G if needed.
cycleguy55 likes this.
Old 02-15-2019, 01:59 AM
ALF's Avatar
ALF ALF is offline
Hi Mark
I assume, as you mentioned the brushes, you did not find some diode plates in the bin?
Old 02-15-2019, 03:34 AM
ALF's Avatar
ALF ALF is offline
Are the brushes C3SZ10347B?
Old 02-15-2019, 04:09 AM
Yes, those are the brushes I have. And I do have some used diode plates but I will need to have them checked at the alternator shop. You already have a bad one, you don't need to pay to ship another bad one!
Old 02-15-2019, 04:18 AM
ALF's Avatar
ALF ALF is offline
Great!!
PM sent
Old 02-15-2019, 09:37 AM
ALF's Avatar
ALF ALF is offline
On ebay both got sold...
But i hope on them from Mark IV
Old 02-15-2019, 01:16 PM
CompClassics's Avatar
When reassembling the back case do not forget the two mounting spacers that go on the mounting studs prior to assembly. Also there is a hole on the rear portion of the case to slip a pin into to hold the brushes away from the armature, pull the pin out after reassembly.
Old 02-15-2019, 01:22 PM
ALF's Avatar
ALF ALF is offline
Thank you John
