Like Tree5Likes
  • 1 Post By Gpkrider
  • 2 Post By spdbrake
  • 1 Post By cycleguy55
  • 1 Post By S1965C
Old 11-12-2020, 05:05 PM
Default Proper "burping procedure"?
I built my 351w and had it installed by my local guy ( I don't have a lift).
Old engine never overheated. Drove it two miles and she overheated. I suspect its airlocked.
Old 11-12-2020, 05:38 PM
Tom Wells's Avatar
in,
I have an overflow can for my radiator, so I just warm the engine, let it cool, and top it off. The air goes out as the coolant expands when the engine warms. After a few refills the overflow can gets enough water pushed into it which then is sucked back into the radiator as the engine cools.
If I could get to it, I'd prefill the overflow can. Since I can't get at it, this method works fine but takes a few more heat/cool cycles.
It usually takes 4 or 5 cycles to get all the air out.
Been there; if there's air, the thing will overheat fairly quickly! After it's full it will happily idle or cruise slowly all day long.
Tom
Cobra Make, Engine: Shell valley
This has worked for me before, normally the radiator has to sit higher than the engine so you can use ramps or jack it up so front end is raised, then completely fill radiator till it’s ready to overflow while evacuating the air bubbles till none are evident, put back on ground and start with radiator cap removed, run 5-10 minutes till thermostat opens, replace cap and go drive. Hope this helps
Tommy likes this.
Old 11-12-2020, 05:42 PM
Burping is usually not a real big issue in an SBF. Some folks jack the front end, park on inclines, etc.. though.
What can be an issue I see it close to 50% of the time on new sbf builds is a CCW waterpump and timing cover being driven CW (clockwise) and also a CW pump being driven CCW. The pump impeller does not pump hardly at all as only the tips grab water.
If you can post the part numbers for the timing cover and water pump you used and a pic of your pulley belt orientation that can be answered pretty quickly.
Ozzie Goat and MKS427 like this.
Old 11-12-2020, 06:05 PM
MKS427's Avatar
Cobra Make, Engine: FFR MkIV 427
Do you know for sure you have air trapped? Before you get too far in this, you may want to pressure test the cap and the system, first. T-stats mysteriously go bad during rebuilds too.
Old 11-13-2020, 10:19 AM
Cobra Make, Engine: ERA FIA 2158, ERA 427SC 649 sold
When it overheated did it push water out? Sometimes if air is trapped in the engine the temp gauge will not read properly. A good way to remove trapped air is to loosen the temp sender on the manifold near the thermostat housing. I usually drill a 1/8" hole in the thermostat and install the thermostat with the hole at 12 o'clock, this insures there is no air trapped in the engine.
Old 11-13-2020, 12:20 PM
eschaider's Avatar
The best $30 you will ever spend. It uses a vacuum to fill the cooling system.
click here => Vacuum Assisted Radiator Fill
Find it on eBay and Amazon
Ed
Old 11-14-2020, 09:44 AM
I have 12' tall ramps and that was not enough to burp my Cobra (5.0 ltr block).
My parents house is a ranch with full basement built into a hill. The front of the house has three steps. The walk out basement floor has one step down. So the bank drops about 7 feet in 28 feet. Backing the car over the bank worked perfectly. for me. So if you can find a hill of similar steepness that you can drive a car on, it should work.
Old 12-03-2020, 04:52 PM
Thanks a lot guys. A couple of short cycles and a gallon of 60/40 later, she's back to normal.
Old 03-04-2021, 11:16 AM
Cobra Make, Engine: Ford 331 V8
Default Lisle funnel
Lisle funnel system works for me. Good product.
Old 03-05-2021, 05:01 PM
mln385's Avatar
Cobra Make, Engine: BDR
Put one of these in>>> https://shop.advanceautoparts.com/p/...E&gclsrc=aw.ds
Old 03-05-2021, 09:56 PM
cycleguy55's Avatar
Install a thermostat with a 'jiggle pin' the next time you drain the cooling system. It allows air to flow through the thermostat, then closes when coolant starts to flow through. Problem solved.
Gaz64 likes this.
Brian
Old 03-07-2021, 01:13 AM
I used to just drill a couple of bleed holes into the thermostat body.
I know it's really low tech.....
Old 03-07-2021, 06:13 AM
That works great. Just clock the hole to the top. Have also heard of the “aspirin trick”, where you jam open the thermostat with an aspirin and it allows fluid flow and topping off during that initial minute of startup. Then harmlessly dissolves. Never tried it but the concept works.
Gaz64 likes this.
Old 03-10-2021, 01:26 AM
She'd still get a headache.....
