Old 01-24-2021, 06:41 PM
Gus M's Avatar
Cobra Make, Engine: BDR Iconic 427 (Dart SHP-Ford 351W)
Default Ford 427 Z2 Motor
Anyone have experience with the Ford 427 Z2 for a weekend driver?
Old 01-30-2021, 12:51 AM
There is no reason it wouldn't perform well as a driver. At 535 FWHP it's pretty weak for the engine size. They tried to make up for the puny heads by stacking the cam...but it didn't work any better than one would imagine it would. They also don't include the lobe separation...but I'm guessing it's 112 so the engine is probably pretty smooth.
It does, however, make 545 ft lbs of torque...which tells you that this thing is not going to make a ton of rpm...but it will pull a fat lady off a tricycle.
So, if you're just tooling around town, it will a much better than adequate job. Price seems to be pretty decent too. Last, they used decent parts in it so, if it were me, I'd not hesitate to use it.
Old 01-30-2021, 06:34 AM
Gus M's Avatar
Thanks Mark!
Old 01-31-2021, 09:01 AM
Do some research, alot of bad press out there for the frp 427/535. Im having one rebuilt right now that the engine guy is way less than impressed with...oil burner from day one.
Superformance 1764
Built 427W
Aiken SC USA
Old 02-01-2021, 12:44 AM
A. I've never met an engine build that was the least bit impressed with anything that didn't come out of his shop.
B. While he's going through your engine...put a cylinder heads on that thing that has at least a half a chance at moving 427ci of air. Those heads are just fine....for a mild 302.
You'll be glad you did.
https://www.trackey.ford.com/downloa...-6049-z304.pdf
Old 02-01-2021, 09:44 AM
Default Know what you mean
About engine builders with the "if its not mine its crap" attitude, but this pig was never right from day 1. Evidenced by the gallons of oil i've added to the thing over 30k miles...
As for heads its got the Z304Ported heads now, which supposedly flow 10% more than the more pedestrian items...
The power and response was good enough just tired of burning oil...
Superformance 1764
Built 427W
Aiken SC USA
Old 02-02-2021, 08:52 PM
Everyone builds a pig every now and again. Even me.
