Like Tree17Likes
  #21 (permalink)
Old 10-27-2022, 06:04 PM
saki302's Avatar
Cobra Make, Engine: Superformance Mk3, Roush 427
That's ancient gas..
I've never had so much to dump, but some ancient motors like my honda z50 will run on 5 year old gas.
Other than that, you can light it in an oil drum, or find a safe spot to pour it in a drum and let it evaporate.
If you have really cheap friends, some might take a gallon or two mixed into their tank if their car is old and not picky. Over here that's a $12 gift (2 gallons)
renaissance man likes this.
  #22 (permalink)
Old 10-31-2022, 07:21 AM
renaissance man's Avatar
Cobra Make, Engine: SMC Motorcars 289
Send a message via Yahoo to renaissance man
Took her out on an 85 mile run yesterday. New plugs gapped at .044. Ran 90 octane zero ethanol, from "Speedy Stop". Running 4000 rpm at 70 mph, 4300 rpm at 80 mph. Have a 180 degree thermostat. Ran at about 190 at 70 mph and 200 at 80 mph. Never got hotter, driving her hard! No backfires except when letting off gas, to be expected. No acceleration hesitation at all! I think she still needs some tweaking?!
Co-founder of the Texas Cobra Club.
Dave "Ren Man"
  #23 (permalink)
Old 10-31-2022, 07:38 AM
Tommy's Avatar
Backfire (through the exhaust) on deceleration is often due to an exhaust leak allowing air into the exhaust system. It could be at the header or any connections downstream from there.
Tommy
Previously owned EM Cobra
  #24 (permalink)
Old 11-01-2022, 10:52 AM
Originally Posted by twobjshelbys View Post
Those plugs look awful. They're fowled pretty bad. I wouldn't declare rich or lean until I replaced them and started over. I can see why it might want some extra kick from starter fluid. Put in some new ones and see what happens.
Second, what is all the rust on the exposed part of the plugs? Was it stored in a very humid area?
I replaced the plugs. Old ones were gapped @.035.
New ones of same type, out of the box were gapped @.044.
Definitely runs better! Still needing starter fluid just to get it to turn over? Not sure why?
Dave "Ren Man"
  #25 (permalink)
Old 11-01-2022, 11:24 AM
sunman's Avatar
Did you clean the carb?
Chaney Shores Studio
  #26 (permalink)
Old 11-01-2022, 06:33 PM
hauss's Avatar
Cobra Make, Engine: 427 manowar forged crank roller rockers . BIG CAM.
air leaks replace gaskets and hoses
  #27 (permalink)
Old 11-01-2022, 06:44 PM
sunman's Avatar
Look into the carb, open it wide open, are you getting an immediate accelerator pump shot of gas?
  #28 (permalink)
Old 11-02-2022, 05:29 AM
Cobra Make, Engine: ERA#134 427 Ctr oiler 2x4's
Again I say check inside the distributor cap for corrosion. That will cause backfiring and hard starting.
Tags
289, backfire, ignition, timing, tuning
