Old 01-05-2003, 06:52 PM
Cobra Make, Engine: Kirkham 482 ci alum block
Default SB or BB
How would you rate this motor????????????
Old 01-05-2003, 08:00 PM
Jeff Frigo's Avatar
Small block based on of course a Chevy.
FALCONER V-12
HIGH PERFORMANCE PRODUCTION RACE ENGINE
SUPPLEMENTAL FACT SHEET
WEIGHTS & MEASURES
- 600 CID
- 522 LBS.
- 4.125” BORE
- 3.750” STROKE
- 23.5” WIDE; 23” HIGH; 36.5” LONG
(WIDTH FROM CRANKSHAFT CENER LINE)
(LENGTH TO FRONT ACCESSORY DRIVE PULLEY)
- ALUMINUM BLOCK & HEADS
PERFORMANCE
Running Race Gas:
- 1100 HP AT 6500-7000 RPM NORMALLY ASPIRATED
- 1200-1600 HP SUPERCHARGED OR TURBOCHARGED
PACKAGE
Each engine is dyno tested upon completion and
base price includes the following:
- ECU
- DRY SUMP
- INDEPENDENT RUNNER MANIFOLD
- DIRECT FIRE IGNITION
SUPERCHARGER OR TURBOCHARGER ADDITIONAL
Jeff
Mark Donahue
Old 01-06-2003, 11:18 AM
Jeff,
Thanks for the great info. But, you got admit that motor would pretty awsome in someone Cobra. Too BIG for my JBL
Old 01-06-2003, 02:31 PM
Tongue Pirate's Avatar
What's the price on something like that? Why not use it on a lambo kit or something that it would sound correct in?
Hyde D. Baker
Old 01-06-2003, 04:26 PM
I don't know about the automotive version, but when I spoke with them at the PRI show last month, the aircraft version was around 80K.
Old 01-06-2003, 08:07 PM
Jeff Frigo's Avatar
That is one small block I would have in my Cobra if it would fit.
Jeff
Mark Donahue
Old 01-06-2003, 08:32 PM
Back in Black's Avatar
Thumbs up If only it would fit
In a Diablo kit..THAT would sound and perform awesomely..IF you could find a transaxle that could take the HP.
