Old 01-11-2003, 01:58 PM
Send a message via AIM to Robb
Default compression ratio for 91 octane
What is the highest compression ratio you can run, when you plan to use 91 octane gas?
(no gas addives?)
First, assume aluminum heads.
Second, assume iron heads.
-Robb
Old 01-11-2003, 02:03 PM
wicked fast's Avatar
The longest build.....
Cobra Make, Engine: Mid-States, 428 Police Interceptor, TKO 5 speed, Jaguar rearend, Trigos, and Guardsman Blue!!!
Thumbs up
George at Gessford told me:
aluminum heads-10.5 to 1,
iron heads 9.5 to 1.
Bill Cook
If you were to die tonight, are you 100% sure
that you would go to Heaven ??
www.bluecarministries.com
Old 01-11-2003, 04:12 PM
HighPlainsDrifter's Avatar
Thumbs up
Robb;
A couple other things to consider besides static compression is cranking compression.Alot of timing will detonate also.
Total timing should be 36 to 38 degrees.
You can get away with a little more compression if you run a cam with enough duration to bleed off some low end power. eg; say 230 to 244 degees at .050 lift will be more tollerant than a 210 to 220 cam.
Perry.
Old 01-11-2003, 06:05 PM
Jeff Frigo's Avatar
Ditto to wicked fast.
Jeff
Mark Donahue
Old 05-02-2003, 02:58 PM
flipper35's Avatar
On the Mopar engines I hace seen 11.2:1 in AL and 10.5:1 with Iron, both with cams using the correct ramp speeds for the larger MP lifter bore.
Also, the timing is dependent on several things including piston shape and cumbustion chamber. For instance a quench style head/piston will require 36* and a flat top regular wedge chamber requires 34* because the flame front spreads quicker here. Of course this is for a Mopar small block and your requirements will differ.
Brent Dolphin
Old 05-02-2003, 05:24 PM
George Snyder's Avatar
Robb,
This may help answer your question.
http://cochise.uia.net/pkelley2/DynamicCR.html
Bud
