Old 02-06-2003, 07:54 PM
Question Cobra small block?
I have recently pulled a 1964 Hipo 289 small block out of a boat. It has the Cobr pan, Cobra intake, Cobra valve covers. The block casting number is c3oe-f and the heads are c3oe. On the back side of the engine below the left head is a stamped number 5478 and there is also a number stamped in the block on the front left head mating surface. Could any body tell me if there is any significance to those numbers? Thanks
Old 02-10-2003, 05:36 AM
Cobra Make, Engine: ERA 289 FIA #2086, 302/320 HP, Dart heads, hydraulic
The code indicates it is from a 1963 Fairlane/Torino
Here is a link to some general decoding info for Ford Motors.
http://www.classicmustang.com/decoding_part_numbers.htm
Jim
Old 02-19-2003, 11:40 PM
Rick Parker's Avatar
Thumbs up
That vintage although correct for early Cobra, has a 5 bolt clutch housing and limits options for clutch and related parts and transmissions too, because of the bolt pattern on the transmission mating surface of the clutch housing. Small blocks run HARD and look nice when dressed up. (check photos in my gallery)
.........Rick
