Old 02-12-2003, 06:28 PM
Scott S's Avatar
Charter Club Cobra Member
Cobra Make, Engine: My Shell Valley Coupe is here! Now the building begins....
Question Help me find the right piston
I am building a 393 with a Scat crank and stock length rods. I am trying to pick the correct piston for 9.5-10 CR with 64cc iron World Windsor heads. The cam won't be huge so valve clearance should not be a problem. Forged pistons preferred.
Scott S
Working as hard as I can every day to double my carbon footprint.
Old 02-12-2003, 06:52 PM
SSSnake's Avatar
Cobra Make, Engine: ERA FIA #2078. 331 stroker, sportsman block built by Evanuik Performance. 450hp
Send a message via AIM to SSSnake
I'm not sure about the correct piston for you application but my engine builder uses JE forged pistons in almost all of his engines.
Glenn
Old 02-13-2003, 05:31 AM
Cobra Make, Engine: FFR4067, 393W
Scott,
I'm building a 393 as we speak.
The KB 192 hyperuetectic with a 12cc dish will give you 10.2 to 1.
That's what I installed with the World Victor Sr. 64cc heads.
If you want less compression you'll have to go with more dish in the piston.
<http://www.kb-silvolite.com/calc.phtml> is very easy to use for calculating compression ratios.
I don't see the need for forged pistons, but that's just me.
Ed
We used to own the government, now the government owns us. Where'd we go wrong?
Old 02-13-2003, 07:43 AM
Mr.Fixit's Avatar
I really like ROSS pistons
Old 02-16-2003, 12:17 PM
Scott S's Avatar
Thanks guys you solved the problem!
Scott S
