Old 06-11-2003, 10:31 AM
Tony Radford's Avatar
Cobra Make, Engine: Unique 427 SC, Southern Automotive 427W Stroker
Default Valve adjustment
Out of curiousity, how often do you adjust your valves on your hydraulic cam/lifter setups? What do you consider a good "rule of thumb" (every X miles) for periodic adjustments?
After a good hard ride.....oil pressure is over 50, temp is below 190, she idles and no new dents. LIFE IS GOOD!
Old 06-11-2003, 02:51 PM
SCOBRAC's Avatar
Cobra Make, Engine: -Sold- Contemporary 427S/C # CCX-3152 1966 427 Med Rise Side Oiler, 8v 3.54:1 Salisbury IRS, Koni's.. (Now I'm riding Harleys)
Hugh? Same time you replace the timing chain... It shouldn't need it. If you NEED to do it you likely have lifters that need replacement.
If on the other hand you are single and need a good manly excercise to impress your babe dujour do it as needed.
michael
A man that is young in years, may be old in hours, if he have lost no time. But that happeneth rarely. Generally, youth is like the first cogitations, not so wise as the second. For there is a youth in thoughts, as well as in ages... Sir Francis Bacon (1561-1626)
Old 06-11-2003, 02:55 PM
WHAAATTTTTT!!!!????!!!!! YA gotta adj. hydraulics? HM Guess I did it about 2 yrs ago Iffin ya gotta adjust em.I'm goin to solids.
Old 06-11-2003, 03:13 PM
Mr.Fixit's Avatar
Sometimes rocker nuts back off, it happens. That's why I like polylocks.
Old 06-11-2003, 05:51 PM
It would seem to me that rocker arms on a high lift cam would still move a tiny bit, even with the hydraulic effect. Wouldn't it just be less noticable?
Old 06-19-2003, 11:45 AM
GeorgiaSnake's Avatar
Cobra Make, Engine: Sold - Unique FIA - SA 396 Stroker
Tony - Call Bill or Lewis
Sold the Unique - Bought a Porsche TT - Sold the TT - Bought a truck
