07-17-2003, 12:38 PM
IL
Cobra Make, Engine: SPF/white/blue/smallblock427/webers
Side pipe temperature
07-17-2003, 01:13 PM
Cal
How much run-time does your engine have?
New motors often run very hot, header glowing hot, for the first 10-40 minutes. The oil and water don't get hot, but the EGT sure is up there.
07-17-2003, 01:17 PM
IL
My total engine run time is about 1/12 to 2 hours.
07-17-2003, 01:36 PM
Cal
How do your spark plugs look?
07-17-2003, 02:24 PM
IL
Spark plugs are fine, Tan to slightly darker. I have not run the car at WOT yet . Most of my driving has been light accels upto 3000 rpm or so. The idle circuit on the Weber 48IDA's will take you up to about 3000 rpm then you transition over to the mains.
07-17-2003, 02:34 PM
Cal
just making sure you aren't too lean, that will spike the EGT.
How far off the body of the SPF are your pipes, (especially the primaries)? Sometimes these things need spacers. Are the pipes painted or ceramic coated? If they are just the regular SPF high temp black paint, they will turn greyish if very hot, like their headers do. You aren't the first guy to blister the paint next to the sidepipes, but it is usually only that hot during the break-in of the motor, not like that 1.5 hours later. Of course, if you blistered the paint right away when the motor was super hot, how would you now know that the EGT has gone down to acceptable levels? I suppose you need an IR pyrometer and another cobra to compare your readings to.
07-17-2003, 04:08 PM
IL
I can slip my flat hand(about 1.0-1.5 inches) between the body and the inside edge of the sidepipes all the way, front to rear. There is a minimum of 7/8 inch clearance at the top, front and bottom of the sidepipes to the body and over 1.5 inches of clearance from the rear of the sidepipes to the edge of the body at the exit hole in the fenders. The pipes are jet hot coated black. Once I get a IR pyrometer I will definately know more. Until then I will just have to be carefull !
07-17-2003, 07:11 PM
Mi
Tommyboy.
For a little comparison our DV's, (Viper powered) Cobras run around 875-1125 approximately five inches back from the collector. We keep a half inch clearance and never have a problem with paint blistering.
I would think a solid guess of 650 to 900 on your car would be very close. Sounds like it simply needs a little more breaking in
DV...
07-18-2003, 10:11 AM
Tommy - check with your Superformance dealer and get a set of stainless steel heat deflectors. Easy install and they cure the heat problem at fender exit.
Have them on mine and they work well.
Lynn
"Cool Toys use 93 Octane"
07-28-2003, 09:24 PM
sidepipe heat
read my private message
