Old 08-26-2003, 09:52 AM
Question solid roller lifters
will a solid roller lifter work on a hyd. roller cam
Old 08-26-2003, 10:09 AM
Hotfingrs's Avatar
Cobra Make, Engine: EM cobra, 450 inch sbc running a best ET of 9.14..so far..ALL MOTOR...approx 800 horse.............ERA with 482 FE..All Aluminum Engine
Send a message via Yahoo to Hotfingrs
they'll work, if you don't mind replacing the cam in a few hundred miles....
Jack
XSSIVE .....
Old 08-26-2003, 12:32 PM
Cobra Make, Engine: None Yet
No! The hydraulic cam does not have the opening and closing ramps that the solid lifters require. It will be noisey and will self destruct.
auto10x
Bill
Old 10-08-2003, 01:08 PM
. . .yes you can. It has been done for years. A light lash of generally .008" and .010" on the rockers is set. This has been a common practice for years. No damage to the camshaft at all. It all started with the class racing of hyd. roller engines and the valvetrain problems they faced due to the mass of the lifter and the inability to use a stiff spring to dampen the mass without colapsing the hyd. valving.
Just came upon this during a search and thought I would add some insight.
Cstraub
Old 03-09-2004, 08:47 AM
Cobra Make, Engine: FFR 1496 289 hi-po.
What about the opposite?
Using hyd roller lifters on a solid roller cam.
Its a small roller 586" lift 244@.050 duration. I only turn it 7000 and its a small 289.
Advantage would be quieter, could use smaller springs (perhaps "beehives")
The solid would have steeper ramps but given that its small may work.
Any input?
Brian
Qwik 1 289/tremec/10.74@123/normally aspirated
Old 03-09-2004, 12:29 PM
Hyd. rollers on solid cam should work fine.
auto10x
Bill
