Old 09-17-2003, 07:09 AM
Cobra Make, Engine: Kirkham 482 ci alum block
Default question 351 ford water pump
I have a ford water pump that had two tube outlets on the side. They have been cut off and plug with 2, 3/8 npt plugs. Will this effect the water circulation and cooling??? or do I have to run these water bypass????
Old 09-17-2003, 07:24 AM
Cobra Make, Engine: Classic Roadsters 351 Windsor 405 HP
I think they are the heater hose hook ups?
Old 09-17-2003, 10:15 AM
Roscoe's Avatar
Dave,
The outlets are for the heater. However, you should run a line from the thermostat housing to the UPPER outlet as a bypass. You can leave the lower one blocked.
Roscoe
Roscoe
